Attic Window -How to Show on Plan View?
Anna_Gorres
Hello All,
We have the side of a garage facing the front elevation. We are placing a window in the attic for front curb appeal. The only place this window shows up in on the attic floor plan. How do I get it to show on the main level floor plan, or even the roof plan, in order to dimension it.
Your help is appreciated!
Anna
Anna,  Javatom's suggestion is likely the correct solution but if you have your reasons it could be done the way you are asking by copying the window down a level and maintaining it's position in the wall by using the same absolute elevation as it was using in the attic wall.
4 hours ago, Kenoeightspot said:
Place the window on level 1 then in Elevation view move up to attic.
That to me would be a BIG no-no...the window is displayed on the wrong floor and as sure as I am sitting here, that window will get framed into the first floor wall. I would add a note on the elevation that reads; ATTIC WINDOW xx" X xx" TO BE CENTERED IN ATTIC WALL W/ R.O. PER MFG INSTRUCTIONS.
But that me...
