Scottb
ANGLED ELEVATIONS
I built my plan at an angle.  now I can't get a cross section that is 90 degrees to my building.  Any ideas?
Sorry if I'm not fully getting this but can't you just take the camera view from 90 degrees off the plan?
Just shoot a new cross section at any angle you want.
Scott,
Create a new "Cross Section/Elevation".  You can set the direction as you are placing the camera.
Its not that easy.  you can't pick what angles it moves. I even turned on my angle snap grid.  but that only moves in 10 degrees increments.  What If I only want to move it 2 degrees?  I can't seem to do custom angels with this.  Thanks for the help.
how do you change your angle snap grid to move by only 2 degrees?
Turn off angle snaps,  draw a construction line perpendicular to the wanted view direction,  now shoot a camera shot along that construction line that is perpendicular to the view....  the camera should snap to the construction line.
Defaults, Plan
Allowed Angles - Additional Angles
Scott's method works perfectly as well.
Draw a CAD line roughly perpendicular to the elevation you want to shoot. Select the line and use the Align>Perpendicular command to align the line perpendicular to the elevation. Turn on your Snaps, enter the Cross Section/Elevation command and snap the camera to the CAD line.
EDIT: Scott beat me.
39 minutes ago, joey_martin said:
CTRL D.....it's your friend....
It might be my friend but I am not sure what it does.  Would you mind explaining what it does.  We with our own hot keys do not understand control d
OOB hotkey for Make Parallel/Perpendicular
Got it,  thanks.  I assume that applies to the cad line and not the camera.  The parallel/perpendicular does not work for camera. It does work for the line that you may want to use to get the direction of the camera correct.   Joey posted one of those cryptic posts that someone can spend 10 minutes figuring out,  thanks Joey.
"Hello pot...kettle here....you're black."
I am sure I deserve the comment.  Thank you.
    28854
    RileyCrosby
    RileyCrosby
  • Similar Content
    • By ericepv
      Rochester, NY based rendering company available for remote work. I am a long time Chief user (currently on X-12 but equipped with earlier versions also) and have worked for many commercial and residential clients across the country. You can view samples of my work on my website https://epvisualz.com .
      Please contact me directly at 585-441-5291 or by email: eric@epvisualz.com .
    • By steve_mcdowell
      Looking for design partner for upcoming projects. My previous designer used Chief and he is too busy to take on additional work. Ideally looking for someone who may have building experience in addition to being a designer. Looking for someone who can deliver preliminary floor plans and elevations to facilitate proof of concept, someone who can design to specific standards for ARC review and submission standards. The designer will need to understand page naming conventions and all related requirements for the city of Bend Oregon for streamlined permit submission. Structural drafting and coordination with structural engineers.
      See attached files as example of the type of drawings needed
      A0.01 COVER SHEET.pdf
      A0.02 PLAN NOTES.pdf
      A1.01 SITE PLAN.pdf
      A1.02 MAIN FLOOR PLAN.pdf
      A1.03 LOWER FLOOR PLAN.pdf
      A1.04 FOUNDATION AND LOWER FLOOR FRAMING.pdf
      A1.05 LOWER ROOF AND UPPER FLOOR FRAMING.pdf
      A1.06 UPPER ROOF FRAMING.pdf
      A2.01 EXTERIOR ELEVATIONS.pdf
      A2.02 EXTERIOR ELEVATIONS.pdf
      A3.01 BUILDING SECTIONS.pdf
    • By sascea
      Does anyone know how to change the decimal under the story pole marker lines? I've attached a picture, it's the numbers circled in orange. I would like to get rid of them completely as some of my story pole markers are close together and this takes up extra space.
      Thank you in advance!!
    • By Designer100
      I have issues at the rear of the building with slope up to rear carport. Can anyone assist in having a slow slope up to carport on each end? the exist. carport concrete is around 42" above grade. same as existing bldg
      I would appreciate help.
      Newell Cheatheam
      newell@newellcheatheam.com
      CA x12
      Moheb Building New.zip
    • By Designer100
      i have been trying to work this rear roof out and cannot seem to close it up.
      I would appreciate anyone assisting me. this is all i like finishing up this project.
      Thanks,
      1411 Plan .zip
