capitaldesigns
Glass window not showing correctly
I am working on a small TI job. In the reception area job we added a 42" high wall with 42" glass panels above.
The existing doors in this room have glass panels. When I did a rendering of the new wall with glass panels above
the glass doors in the background have a crackling appearance. It should be clear glass.
I have attached the file so you can see what I am talking about. Does anyone know why this is happening and
how to correct it ?
Thanks,
Mike
PTI_Technologies_Remodel.plan
Raytracing through multiple layers of glass is problematic and it can take a "lot" of passes to clean things up. Try making the glass in the elements behind the front glass screen 100% transparent or change the glass to a general material with a high transparency. Might help.
Graham
Graham
I'm getting the same thing here. Tried this tip - doesn't seem to help.
I know, it's a real problem. Try turning off Photon mapping or eliminate the glass altogether. Make the window a pass through, not sure how you deal with the door. There was a discussion on this about 6 months ago, not sure anyone was able to come up with a real solution.
Graham
Mirrors will also do this , you cannot have mirrors reflecting into other mirrors.
The problem in this plan relates to the light settings. I turned off all of the lights and added a few of my own. No problem with speckles, added a few pics on the wall in the offices so you can see. Runs a lot faster now, 50 passes in 2.5 minutes.
Graham
If you wish to have the lights as per the original plan then turn the Photon mapping off. Still runs like a pig but glass will be clean. These took about 3 min. for 2 passes.
Photon Mapping Off - no speckles
Photon Mapping On - speckles
Graham
Does the Auto Adjust Default Glass Properties setting in 3D View Defaults make any difference?
Just a stab in the dark.
Thanks guys for the help. I tried Graham's suggestions and turning off Photon mapping worked.
I did not try turning off all of the lights yet. I see in the rendering you posted that it still looks like
the fluorescent lights are still turned on. If you turned off the lights in the rendering how did you
get the fluorescent light to appear to be turned on ?
Thanks,
Mike
???  The attached was either X7 or X8.  It's all about the lighting.  One bad light position or light against the wrong material and fireflies and glass ripples will never ray trace away.
What you show is a mirror where you are seeing Glass in the mirror(it seems), but what I'm talking is where you see a mirror in the mirror in rendering mode
My mistake.  Yep, render mode has issues.  And if you look again, there is mirror on mirror on mirror (Wall, closet doors, ceiling) in this rt.
I should have said "Renders" in my posts, I really don't do a lot of raytraces, but when I do they are the fast "Crappy" ones, under 3 min. .   I put out a lot of construction doc.s for the building departments and they don't care about pretty pictures. I use some Rt's for the client prelim's only.
Thanks everyone for your help.
Jon, I like your gym rendering. I can see that you are looking through several mirrors with the crackling effect.
You said that " It's all about the lighting.  One bad light position or light against the wrong material and fireflies and glass ripples will never ray trace away"
Is there there certain distance that we should keep our light sources away from glass and mirrors so we do not get the ripples in the ray trace ?
What other materials would be negatively effected by a bad light position ?
I turn off all my lights and just use light sources.
Mike, I'm not sure what's going on with your model.  It's just grainy in rt.  That leads me to believe there is a bad material(s) somewhere within the plan.  A couple things I did notice.  Turn off all lights not directly influencing the view.  Try doing what Perry suggests and use light sources for the majority of the illumination and fixture specific lights only where they are visible in the camera view.
Sorry, I don't have the time to hunt down the offending material--it can be a challenge.
Thank Jon for your help. Now I am having a problem with the stainless steel refrigerator and dish washer appearing to be black in the break room.
There are two areas of remodel. The first being the waiting room which you have been helping me out with and the other being a break room.
The break room is off to the right of the partition wall with glass above and is open to the waiting room. I did both ray traces about the same time.
The break room worked fine. The waiting room was the problem area. Now that I have turned off all of the lights in the waiting room and added light
sources, the wait room is looking good. Now the stainless steel appliances in the break room are not showing correctly and appear to be black.
None of the lights were turned off in the break room. I am using the same camera view as before. I made no changes to the break room.
Why now would the stainless steel appliances not show correctly ?
Thanks,
Mike
You'll need to turn photon mapping on to get rid of the black metal.
When I looked at this it appears that the grid ceiling light fixtures are the issue. There is always a high risk of these speckles in the glass when the light source has to pass through a lights lens or transparent shade and then through more transparent materials such as glass in windows and doors. In this plan the light from it's source is passing through 3 transparent materials before getting to those back offices. If the lights are point type and photon mapping is on that's a huge number of calculations which is also compounded by the number of light sources. Theoretically, things should get cleaner as the number of passes increase however, this plan takes so long to run even a single pass I'm not sure one would have the patience to wait to see what this would look like after say 100 passes. Also, the calculated corrections per pass follow the law of diminishing returns, as each pass completes the apparent correction lessens.
Graham
Graham, I turned off all the lights, merged the multiple "Glass Standard" materials and replaced fresh from the library, dropped a camera view directly in front of the large office window, and added four light sources (inside office, outside office, left of camera, and behind camera) and the shot was very grainy after 10 passes.  I tried w/wo photons and caustics--no change.
Jon - Without seeing your exact plan it's difficult to know exactly what is happening. I did post renderings earlier on that showed the results I obtained, all of them had some form of light source. Also, point lights are more problematic than spot lights as their light paths are calculated differently. This issue can also be affected by the balance between a light sources intensity and the ambient light source intensity. It's very easy to have the lighting set where if you think of this in photographic terms the pic is way over or under exposed. Too much light in the room will overwhelm the Raytrace engine, it just can't adjust no matter the number of passes.
Graham
Mike - The way your lights and materials are set you will need to run your break room with Photon Mapping turned on. Would suggest turning off those grid ceiling lights so you will be able to Raytrace in a reasonable length of time. If you want to run this with Photon Mapping off then you will need to change your lighting and most likely the stainless steel material/properties so they do not show as black. When Photon Mapping is turned on the Raytrace engine is calculating multiple light bounces and as such your stainless steel will show correctly due to light bouncing off of the walls, floors, ceilings and other objects in the room. When Photon Mapping is turned off then this light bouncing is not calculated, to get the stainless to show correctly you would need to add additional lights specifically directed at the stainless steel or you would need to change the stainless steel properties/material to compensate for this.
Graham
    29120
    Amanla
    Amanla
  • Similar Content
    • By Aamir77
      Hi folks,
      I want to create a corner window with two different profile windows where height is different on both faces of windows like the one circled RED in this picture.
      I tried but failed to remove the corner post if I change the height of one side like this
      Need your guidance. I am using x10.
      Thanks in advance.
    • By nikiley
      Hi All!
      I am wondering if there is a way to add hardware to a window like sash locks or casement cranks. I did not see any options in the window specification dialog, but I wonder if I could create something to apply in the treatment tab that would work. Has anyone here experimented with something like that?
    • By ChiefuserMathews
      Is it possible to create a wall type as attached in the image?. This is for a roof top patio partition wall. Could some one guide me please.
    • By HDbyJustin
      Hello everybody. I have recently made the jump from the Home Designer Pro series to Premier X12. I have a client that wants the windows to be labeled with letters instead of numbers. I have not seen a way to change that but am I missing something?
    • By DTCBuild
      I design for a builder who uses concrete walls (Ritek). The builder wants the plans to show the window size correctly with the cutout 40mm larger all round. I see you can do this with stem walls. Is there a work around for normal walls? Doors are ok, I just make the jamb 40mm wide. This doesn’t seem to work for windows. The wall manufacturer wants to read my cad files, measuring the rough openings.  Any suggestions would be great, thanks
