doitright Posted October 16, 2016 Share Posted October 16, 2016 I am using x7 and had a recent hard drive crash. I recovered my files and reloaded Chief but now have some problem getting the right line weights when printing layout. The interior elevations are the problem when using a combination of cad lines and objects. The objects are much darker than the cad lines. I was using the default settings and played around with different weights in print setup but can not get it right. What am I missing? RJ Buhler Link to comment Share on other sites More sharing options...
ShaneK Posted October 17, 2016 Share Posted October 17, 2016 post the plan and layout file Link to comment Share on other sites More sharing options...
doitright Posted October 17, 2016 Author Share Posted October 17, 2016 See attached elevation pdf and the same file sent to layout. the plan drawing shows up fine on the layout. LAKVIEW Layout 24 X 36-Layout.pdf Elevation print.pdf Link to comment Share on other sites More sharing options...
ShaneK Posted October 17, 2016 Share Posted October 17, 2016 Adjust line weights of items with heavy lines, layer dbx or default settings or ........... Link to comment Share on other sites More sharing options...
doitright Posted October 17, 2016 Author Share Posted October 17, 2016 I have tried adjusting the line weights from 1-100 to 1-1000 and it does not make a difference when printing the layout. Adjusting the layout line weights just changes the cad lines. I am not familiar with dbx settings. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 17, 2016 Share Posted October 17, 2016 "dbx" is short for "Dialog". The Layout Box "Layer Set" should control the line weights of the objects. Check to make sure your Layout Boxes are using the correct "Layer Sets". Select a Layout Box, then select the "Layout Box Layers" icon on the Edit Toolbar. This will allow you to either select a different Layer Set or modify the layers within the current Layer Set. Link to comment Share on other sites More sharing options...
doitright Posted October 17, 2016 Author Share Posted October 17, 2016 So I use pretty basic tools and the only layer set in Layout is the Default set. In the layer set there are no "objects" in the list that can be adjusted. If I was able to adjust it in the layout it would likely adjust in in floor plan view as well and the floor plan line weights are good. It is only in the section views were the problem occurs. I went to the section drawing and adjusted some object line weights there and it made a bit of difference but it seems a lot of work to have to adjust all the objects from their standard settings. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 17, 2016 Share Posted October 17, 2016 So I use pretty basic tools and the only layer set in Layout is the Default set. In the layer set there are no "objects" in the list that can be adjusted. If I was able to adjust it in the layout it would likely adjust in in floor plan view as well and the floor plan line weights are good. It is only in the section views were the problem occurs. I went to the section drawing and adjusted some object line weights there and it made a bit of difference but it seems a lot of work to have to adjust all the objects from their standard settings. Read Post #6 carefully. Link to comment Share on other sites More sharing options...
doitright Posted October 17, 2016 Author Share Posted October 17, 2016 Attached is a screen shot of my layout layer set. I appreciate your help on this. Link to comment Share on other sites More sharing options...
doitright Posted October 17, 2016 Author Share Posted October 17, 2016 sorry, here is the attachment Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 17, 2016 Share Posted October 17, 2016 I think Joe is talking about the plan layers set, not the layout layer set Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 17, 2016 Share Posted October 17, 2016 I think Joe is talking about the plan layers set, not the layout layer set Yes, and No. When you select a Layout Box on a Layout Page - there's an icon on the "Edit Toolbar" which is normally at the bottom of the screen. The Icon allows you to see (and edit) what Layer Set is being used by that Layout Box. Normally it will be the same as the one in use when the view was Sent to Layout. Editing it will not change the Layer Set in the Plan. Link to comment Share on other sites More sharing options...
doitright Posted October 17, 2016 Author Share Posted October 17, 2016 I tried that Joe and it did change it on the layout print. I changed a base cabinet line weight from 25 to 5 and it looks about right. If go thru and change all objects, walls, electrical etc to different line weights from the default it may work but not something I have ever had to do before. ??? Link to comment Share on other sites More sharing options...
Kiwideziner Posted October 17, 2016 Share Posted October 17, 2016 What are your settings in the drawing sheet setup? particularly under advanced line weight options. I use 1:100 and then my lineweights vary between 10 and 100 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 17, 2016 Share Posted October 17, 2016 I tried that Joe and it did change it on the layout print. I changed a base cabinet line weight from 25 to 5 and it looks about right. If go thru and change all objects, walls, electrical etc to different line weights from the default it may work but not something I have ever had to do before. ??? When you opened that dialog, what Layer Set did it say was being used? Was it the same as the Layer Set in the Plan? Link to comment Share on other sites More sharing options...
dshall Posted October 17, 2016 Share Posted October 17, 2016 I tried that Joe and it did change it on the layout print....... I think you are correct and JC is mistaken. Link to comment Share on other sites More sharing options...
dshall Posted October 17, 2016 Share Posted October 17, 2016 Yes, and No. When you select a Layout Box on a Layout Page - there's an icon on the "Edit Toolbar" which is normally at the bottom of the screen. The Icon allows you to see (and edit) what Layer Set is being used by that Layout Box. Normally it will be the same as the one in use when the view was Sent to Layout. Editing it will not change the Layer Set in the Plan. I do not agree with this statement.... I think........ Link to comment Share on other sites More sharing options...
doitright Posted October 17, 2016 Author Share Posted October 17, 2016 What are your settings in the drawing sheet setup? particularly under advanced line weight options. I use 1:100 and then my lineweights vary between 10 and 100 My setting for layout sheet is 1:700. At 1:100 it gets much worse in terms of contrast between elevations view and plan view.. Link to comment Share on other sites More sharing options...
glennw Posted October 17, 2016 Share Posted October 17, 2016 Joe_Carrick, on 18 Oct 2016 - 04:32 AM, said: Yes, and No. When you select a Layout Box on a Layout Page - there's an icon on the "Edit Toolbar" which is normally at the bottom of the screen. The Icon allows you to see (and edit) what Layer Set is being used by that Layout Box. Normally it will be the same as the one in use when the view was Sent to Layout. Editing it will not change the Layer Set in the Plan. I do not agree with this statement.... I think........ Well, yes and no. If you change the layout box layer set, it will not directly change the layerset in plan view, UNTIL you double click the layout box to open the plan view. In that case the plan view will reflect the changed layout box layerset. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 17, 2016 Share Posted October 17, 2016 Of course, if you copy the Layout Box Layer Set (thus creating a new Layer Set) then the original Layer Set in the Plan will be unaffected. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 18, 2016 Share Posted October 18, 2016 For a new Chief user , this has to be confusing Link to comment Share on other sites More sharing options...
