capitaldesigns Posted June 11, 2016 Share Posted June 11, 2016 I'm new to Chief, I'm using X-8 I'm getting two different colors showing up in the ray trace than in the perspective view. I have a project that has a long over hang. This over hang is being supported by a beam that itself is being supported by knee braces that are attached to the wall. The knee braces and the beam are painted porcelain white. When I ray trace it the beam has a grayish color while the knee braces are bright white. I created the beams using polyline solids I then changed the material to Fir. In the perspective view I used the material eyedropper to select the color of the knee braces and apply it to the beam. Looks right in the perspective view but not in the ray trace view. I've added lights in front of and under the eaves to see if that would correct the color difference. Still shows a grayish beam and bright white knee braces. Is there a way to correct this color difference? Thanks, Mike Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 11, 2016 Share Posted June 11, 2016 The materials eye dropper has five possible "Modes" which each can deliver a differing result. Look up the "Materials Eye dropper and Painter" in the Reference Manual to study and then practice with until you understand fully the differences between the different possible modes and their out comes. DJP Link to comment Share on other sites More sharing options...
Chopsaw Posted June 11, 2016 Share Posted June 11, 2016 Mike, You may not be doing anything wrong, the material painter has some deficiencies, most of which I am not fully aware but I have had trouble with painting polyline solids a white colour before. Try two coats of paint just as in real life such as you would never expect in Virtual Reality or open the object and go to the materials panel and change it there then post your results. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted June 11, 2016 Share Posted June 11, 2016 An identical colour can raytrace a different shade if it is on horizontal and vertical surfaces due to light striking and reflecting back at a different angle. Assuming that there no material painter issues you can use a different white on each surface and adjust to compensate. Graham Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted June 11, 2016 Share Posted June 11, 2016 As Graham mentioned you can create a different color and turn up it's emissive setting to brighten it. Link to comment Share on other sites More sharing options...
capitaldesigns Posted June 11, 2016 Author Share Posted June 11, 2016 The fascia board, knee brace, beam and garage door and trim are all have the same color selected. Each one has a slightly different shade of white. The knee brace which I selected from the core library is the brightest white. The garage door is a little less bright white then the fascia board a little less bright. Then you have the beam which is a light gray. I can see that the slight color differences would take place depending on the direction of the light source. But the gray beam is right on top of the knee braces. Both of them have vertical surfaces. I would have assumed that their colors would be close to each other. I will try and play with the emissive setting s and see if that helps. Thanks Mike Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted June 11, 2016 Share Posted June 11, 2016 Posting a pic would really be helpful so we can see what is happening. You can also change some settings in the Raytrace DBX that will alter how colors appear. Use "Uniform Intensity" instead of "Ambient Occlusion", turn off "Photon Mapping", set the "Direct Sunlight" to 0. This should help but it will also affect how other items appear as they are global type settings. Graham Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 11, 2016 Share Posted June 11, 2016 Here's what you should really do... Post the plan. Then one of us can take a look at it and give you a much better and more accurate answer. Link to comment Share on other sites More sharing options...
capitaldesigns Posted June 12, 2016 Author Share Posted June 12, 2016 I hate to ask, but how to I attach the file to this post? I do not see anything that allows me to attach a file to this post. Thanks, Mike Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 12, 2016 Share Posted June 12, 2016 Bottom right...Click "More Reply Options". Then click "Browse" and select your .PLAN file (you MUST make sure the plan is closed first). Should be as easy as that. If the plan file is too big you can either try zipping it, strip it down (do a Save As and delete everything that's unnecessary) or simply post a Dropbox link. If the textures your using aren't from the core library you might need to "Backup Entire Plan" and attach that zipped folder rather than just the plan. Link to comment Share on other sites More sharing options...
capitaldesigns Posted June 12, 2016 Author Share Posted June 12, 2016 Thanks. Here is the plan. There is several other mock-ups on this plan as well. The one I'm talking about is the plan at the lower left side of the screen. I have also attached the Ray trace image. If you look at the perspective view the beam, fascia board and knee braces all appear bright white. In the ray trace image the beam looks like a light gray. Thanks, Mike Truss Roof.zip Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 12, 2016 Share Posted June 12, 2016 Your problem is that the beam is PAINTED the porcelain color (the color has been put over the top of the Fir texture). When using the material painter, make sure you have Blend Colors With Materials (the little paint roller icon) toggled OFF. There are very few circumstances where that setting should be toggled on IMO. Link to comment Share on other sites More sharing options...
capitaldesigns Posted June 12, 2016 Author Share Posted June 12, 2016 Thanks Michael. Buy the way, you wouldn't happen to know a John Rankin in Anchorage? He also been doing architectural plans there for many years. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 12, 2016 Share Posted June 12, 2016 You're welcome. And that name sounds really familiar. I think I have friends or colleagues that might know him, but I don't personally. Link to comment Share on other sites More sharing options...
capitaldesigns Posted June 12, 2016 Author Share Posted June 12, 2016 He also plays in a band that tour around Alaska. He use to be the base guitarist for and old rock group called Mitch Rider and The Detroit Wheels back in the late 60's early 70's. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted June 13, 2016 Share Posted June 13, 2016 That was a smoking band! Interesting to know what happens to members of dissolved bands from those days......for me anyhow.... Link to comment Share on other sites More sharing options...
Ridge_Runner Posted June 14, 2016 Share Posted June 14, 2016 Great band from "the day." If my memory serves me correctly they did a lot of the studio work on some of the greatest Motown hits. Mike Link to comment Share on other sites More sharing options...
capitaldesigns Posted June 15, 2016 Author Share Posted June 15, 2016 In the late 80's he move down to Simi Valley, Ca where I live after going through a divorce. He was doing architectural rendering when I meet him. He told me that he use to be the base guitarist for Mitch Rider. I thought he was bullshitting me until a year latter when Mitch Rider came to L.A. and we were invited back stage. After listening to the two of them talking about the old day for about an hour it was clear that he use to be a member of the band. John moved back to Alaska in 1991. We talk a couple of times a year. He is a Revit user. Every time we speak he spends at least a half hour trying to convince me to switch to Revit. Link to comment Share on other sites More sharing options...
