HumbleChief
Archive Preference?
I have mine to set to "previous save"
I don't use the archive system
I prefer to do "save as" and do them often
perhaps every few minutes if I am in high design mode
certainly after finishing a task I'd rather not have to do over again
Lew
Mine are set to hourly. While I do lots of save as, over the years I've gotten compulsive using Ctrl+S almost reflexively.
I understand Ctrl+S and save often but that's not the same as the archive function - is it?
If you have archive set to once a day then even if you Ctrl+S every couple minutes the archive will only be updated per the setting in preferences as I understand it.
When Chief crashes, which is extremely rare, and there is note stating there's a newer version other than the file you're trying to open, is Chief now accessing the Archives? Or some other location that Ctrl+S places the file?
You have it right Larry-Ctrl+S is save- nothing to do with archives. That's why I set it for hourly- I can hit save without thinking before doing a "save as" go on for a while only to discover I need to go back beyond the undo number.
Thanks Mark. I was always told that any back up system is designed to lose you as much work as that back up timing is set to. i.e. If you back up once a week be prepared to lose a week's worth of work, once a day be prepared to lose a day's worth of work, an hour etc.
Just wondering why one wouldn't use the previous save option as that should get you the most recent 'archive' possible - true?
I'm asking because I went looking for some archives (it's rare that i need them) and it just didn't seem like they we all that useful/recent.
Thanks.
Keep in mind that archive files are only created each time you save a plan - archives are not created if you don't save.
I use Previous save.
    27825
    ChiefDallas
    ChiefDallas
