HumbleChief Posted September 16, 2015 Author Share Posted September 16, 2015 Glenn is correct, it is the height of the roof. In the attached plan I've split the roof into two roofs, the main patio roof , and a second for the fill framing. That's the same solution I came up with. Thanks for posting and taking the time. Is this expected behavior in your world of Chief? Would you expect the height of the roof to effect the deck floor like this? Curious and thanks again. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted September 16, 2015 Share Posted September 16, 2015 Glenn is on vacation with no computer and yet he still comes up with the correct source of the problem! Hats off to you Glenn! Link to comment Share on other sites More sharing options...
HumbleChief Posted September 16, 2015 Author Share Posted September 16, 2015 In Larry's plan when I pulled the ridge lower than the deck all was well. That's the trigger from my experience as well. Two roof planes solves it but....hope that will help someone in the future. Link to comment Share on other sites More sharing options...
dshall Posted September 16, 2015 Share Posted September 16, 2015 Glenn is correct, it is the height of the roof. In the attached plan I've split the roof into two roofs, the main patio roof , and a second for the fill framing. Okay Bill, I get your solution. That essentially is what I did in my own personal plan that I posted a picture of. But here is the challenge.... suppose the deck is at an elevation that will eventually get buried by the roof.... how do you deal with that. As you can see by Larry's plan edited by me, I have the deck getting buried into the roof...... I know, not necessarily good design.... but suppose that is what I want..... I am able to do it and I think the reason Larry was not able to do it was because of how he messes around with the floor defaults. No blame intended Larry, just an observation. My goal is to be able to build anything I want in spite of CA's supposed limitations. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted September 16, 2015 Share Posted September 16, 2015 Larry - this was a very interesting post but I still am thinking this may be a bug. Would like feedback from CA. Link to comment Share on other sites More sharing options...
HumbleChief Posted September 16, 2015 Author Share Posted September 16, 2015 Okay Bill, I get your solution. That essentially is what I did in my own personal plan that I posted a picture of. But here is the challenge.... suppose the deck is at an elevation that will eventually get buried by the roof.... how do you deal with that. As you can see by Larry's plan edited by me, I have the deck getting buried into the roof...... I know, not necessarily good design.... but suppose that is what I want..... I am able to do it and I think the reason Larry was not able to do it was because of how he messes around with the floor defaults. No blame intended Larry, just an observation. My goal is to be able to build anything I want in spite of CA's supposed limitations. Always appreciate your feedback but even with corrected floor heights (which I did not mess around with) the problem remains. The 2 roof planes solves it but it took me by surprise. I did send the plan in to headquarters. I'll post what I find out. ..and THANK YOU everyone for all your help!! Link to comment Share on other sites More sharing options...
HumbleChief Posted September 16, 2015 Author Share Posted September 16, 2015 Larry - this was a very interesting post but I still am thinking this may be a bug. Would like feedback from CA. I'm wichoo on that Dennis - I'll post any answer I might get form Tech support. Link to comment Share on other sites More sharing options...
HumbleChief Posted September 17, 2015 Author Share Posted September 17, 2015 Heard from tech support and they suggested a second roof plane to solve the problem. Hope that helps someone else in the future. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted September 17, 2015 Share Posted September 17, 2015 Well we already figured that out. No comment on the issue with the ridge height interference and a possible solution to that so one roof can be used? Link to comment Share on other sites More sharing options...
HumbleChief Posted September 17, 2015 Author Share Posted September 17, 2015 Nope. Text in full; "It appears that once the roof plane below gets to the height of the floor above, the floor structure goes away. I found that if I recreate that roof plane with 2 planes, it works as it should. You should be able to correct the problem with the same alteration. I have attached an image of the change I made. The second roof plane is filled in red.I will submit this to our development team to look into." Link to comment Share on other sites More sharing options...
Greg_NY61 Posted September 17, 2015 Share Posted September 17, 2015 I can see the roof being a problem if a roof plane cuts the deck, but in this case roof plane is nowhere close to the deck, and the top of the ridge is way up there... that shouldn't be an issue. I thought it had something to do with the lack of support for the deck, but looking at the framing details, there is no way this deck can be attached the way it shows. I guess a s^*t load of manual framing has to be done to make this work and if you like to show the framing details. Link to comment Share on other sites More sharing options...
HumbleChief Posted September 17, 2015 Author Share Posted September 17, 2015 Thanks Greg but the plan is in early preliminary development. Lots of decisions still to be made on framing, structure, support, feasibilty etc. The OP was about the deck floor disappearing not the actual design or its feasibility. Still doesn't seem right that the floor would disappear but sure enough it does. Link to comment Share on other sites More sharing options...
glennw Posted September 17, 2015 Share Posted September 17, 2015 Larry, When can I expect my prize? Link to comment Share on other sites More sharing options...
HumbleChief Posted September 17, 2015 Author Share Posted September 17, 2015 I believe that check is in the mail Hey wait, don't I get a prize for figuring out the 2 roofs? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 17, 2015 Share Posted September 17, 2015 I FIXED IT FIRST!! Link to comment Share on other sites More sharing options...
