zowie123 Posted August 13, 2015 Share Posted August 13, 2015 Hi, I have a nicely laid out plan on an 18x24 layout sheet, but I need to upsize to 24x36. What's the best way to get all the info from one to the other? Thank you, Barry Link to comment Share on other sites More sharing options...
Kbird1 Posted August 13, 2015 Share Posted August 13, 2015 Print to PDF and then Print it at 135-150%? on the Larger Paper . I used to Print to PDF on 12x18 at 100% and then have it printed at 200% on 24x36 if needed and it worked fine.... Link to comment Share on other sites More sharing options...
glennw Posted August 14, 2015 Share Posted August 14, 2015 Zowie, Depending on how you want to handle the layout boxes and the title information, sizing, etc. You can change to the larger sheet by going File...Print...Drawing Sheet Setup. This will change the sheet size and place your original layout boxes and title information in the centre of the larger sheet, at the same scale. You may need to edit or move the title information and move the layout boxes. I assume you want all the layout boxes and title information at the same scale as the original and don't want to increase the scales of all the layout boxes along with the sheet size increase. Link to comment Share on other sites More sharing options...
joey_martin Posted August 14, 2015 Share Posted August 14, 2015 Block the 18x24 title block and copy/paste it to the larger sheet and make the adjustments. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 14, 2015 Share Posted August 14, 2015 Some of us have our Default Layout set up with different size Borders, Title Blocks, etc on different layers. Then we have Annosets & Layer Sets so that when we select the Annoset for that Sheet Size all we have to do is use the "Drawing Sheet Setup" function to complete the switch to the different size. As Glenn indicated you may need to move and/or resize some of the Layout Boxes but otherwise there's not much else required. The attached pic shows my Layout Page 0 with all Layers displayed. The sheet size [Arch-D] is currently selected which is the white area. I have Layers for Arch-A, B, C & D 1 Link to comment Share on other sites More sharing options...
zowie123 Posted August 14, 2015 Author Share Posted August 14, 2015 Thank you all for the good info. It's going to take a day to absorb what Carrick is saying, but that's what I'm after. A quick way to choose and change when needed. Thanks again, Barry Link to comment Share on other sites More sharing options...
zowie123 Posted August 14, 2015 Author Share Posted August 14, 2015 And Joseph, thanks for the graphic that helped solidify the concept. Cheers! Link to comment Share on other sites More sharing options...
jbaehmer Posted August 15, 2015 Share Posted August 15, 2015 For me I have one single layout done in 11x17. All plan views are sent to 1/8" scale to the layout. If I need a full size set of plans, I will tell CA to print at 100% at 22x34 paper. Everything will automatically come out printed at 1/4" scale. I have the "scale" macro on plan and elevation labels so it will auto changes from 1/8" to 1/4" depending on the size paper it gets printed on. With how I have it setup, I can print an 11x17 set and a 22x34 set back to back in less than a minute, without having to change anything on the layout like viewport locations, annosets, layersets...nothing. If my client wants 24x36, I still give the 22x34 and the page just has an inch border around it. Haven't had complaints about that, so I feel it works. It is rare for me to have 12x18 requested, but I am thinking of adding that as I have been asked twice in the past 6 months. If I get requests for larger than that, I just take the extra time to change it up....but I have only had to go larger than 24x36 once. Not worth it to me to try and add something like that to my template layout if I only get asked once a decade. zowie123 - I live in Tacoma, so if you want some help, let me know. GO HAWKS! Link to comment Share on other sites More sharing options...
Kbird1 Posted August 15, 2015 Share Posted August 15, 2015 I do the same thing now with 11x17 as one of my own Printer's now will do tabloid Paper , but didn't know your trick of sending to 22x34 to auto get 1/4" scale, I just Print the PDF at 200% for 22x34 at the Copy Shop if needed since I can't do that myself anyway. M. Link to comment Share on other sites More sharing options...
jscussel Posted August 16, 2015 Share Posted August 16, 2015 Jared. I'm using the exact same system as you. Been working good for many years. Jon Link to comment Share on other sites More sharing options...
