part1969
Bar/tavern
Is it built like a house? If so ,why not.
as long as they serve burgers
Yes, you can draw just about anything with Chief.
I've done a Bar, I've also done a Restaurant with kitchen, dining room and bar including all the kitchen/bar equipment.
I did a tavern.
There was engineering, and the engineer called the inside of the
tavern the "Assembly Area".
I did a tavern.
He was probably referring to an Assembly Occupancy Classification (Groups A1 through A4) which defines occupant load so you can calculate all sorts of good stuff like egress widths, fixture counts, structural loads, etc.
I'm considering a restaurant interior design project that has been offered to me however I have never done anything like this and don't really know where to start. Im assuming by your post that you found the software capable of everything that was needed?
Designing the rooms and floor plan on restaurants /bars is the easy part. It's the code check stuff that gets complicated (occupancy, separation where req's, exiting requirements, etc. ). I would consider talking with your planning department before you agree to taking on the work.
This building concept will have a small restaurant on the main floor, and a bar on the roof. Does that count?  :)
Just did a restaurant.  Except for the ones in the library I got all the symbols I needed from sketchup.
Opening April 2, 2016
    27450
    Elliot
    Elliot
