Stair Struggles
Rich_Winsor
OK all of you stair gurus. I have been wrestling with this
innocuous little pour all weekend. This is the door stoop
of a local historical landmark I am rendering so I need
the model to be as accurate as possible. It looks simple
enough until you get to the details. The stairs are poured
concrete with rails cobbled together with 4 x 4 newels,
1 x 4 balusters and 2 x 4 top and bottom rails. Note that
the stairs not only are flared? splayed? outward from the
top of the porch but the treads are also undercut to give
the effect of having a tread overhang. Any ideas, thoughts,
approaches as to how to model these would be greatly
appreciated. So far I have got a pretty good facsimile by
beating it out of the program with brute force but I was
wondering if it is possible to make Chief do the work.
Rich I tried making it using P-solid, but it takes time and lots of tweaking, basically its a pain in the A$$... Still not perfect and need some more tweaking  so it looks perfect at all angles, but its doable if you want to spend time on it.. I'm not that good at it and this is the first time I tried doing that...Maybe someone else can do it better, in less time doing it another way, but here is what I got
The treads and risers are individual p-solids, the side stringers are also... If you want to make it enclosed all you have to do is lower the back to the terrain level.
I have done this using slabs (p-solids are fine too). For the top round handrail, I would use a 3D molding polyline so I could break it and angle it down. You might have to do those balasters manuals too or create your own fence panel.
Thanks for the input guys. Here is what I have come
up with so far. All the cement is built up from slabs. I
used wedges on the front of the stairs (see vector view)
to make the undercut effect. I couldn't get any type of
railing to generate the look I needed so I made a section
of railing (see thumbnail) which worked fine on the flat
portion of the porch but I couldn't make it follow down
the stairs as in the actual construction. Basically I built
the descending rail portions from scratch. I had a play
with attaching the rounded portion of the hand rail on
top by using a 3d molding polyline and it is doable but
will take a lot of niggling to pull off. All in all it's looking
pretty decent in Standard View which is all I really need
for now. Vector View is a little messy in spots but can
probably be cleaned up with a little more precision in
the plan and some touch up work. At least I can see
the light at the end of the tunnel. Unfortunately I didn't
do this mockup to scale so I will have the delightful
experience of doing it all over again using actual dims.
I'll bet that when they built this stoop in 1930 they
never imagined what a pain it would be to generate
in Chief. ;)
in Chief. ;)
Good job, Try ramps. I explained it in earlier threads.
How did you make the Railing section Rich? just curious as the ones I made in the other thread followed the stairs no problem using a manually drawn straight railing ( auto railing off ) and the Balusters set to Panel
OK, so here's the deal. I haven't really spent any time
on the railing so far because I'm sure I can get the look
I need. What I can't do is get the stairs tools to generate
a slab step/tread like the ones in my picture. Forgive the
use of a rogue 3D program but here is a 3D model of what
one of the stair steps needs to look like. I have exaggerated
the tread undercut for clarity. Can this look be achieved
using Chief's stair tools or should I just stick to my first
approach of stacking slabs together?
