Joe_Carrick Posted May 13, 2015 Share Posted May 13, 2015 I can't figure out how to get the Property Lines to have "Quadrant Bearing Decimal Dimensions" to be displayed on the exterior of my property lines except by using a text box. This should be an automatic feature. If I create dimensions, I can manually add the bearing text by copying it into the "Leading Text" but that's extra work and I then have to make the actual dimension line, arrow and extensions somehow disappear. Does anyone have an easy way to have this work? Link to comment Share on other sites More sharing options...
Kbird1 Posted May 13, 2015 Share Posted May 13, 2015 hi Joe, I was watching the Plot Plan and Annotation CA Video yesterday and at about the 11.30-15:30 min mark ,they are playing with those settings in the PL DBX and setting up text styles etc if I understand your question correctly. it is video 5480 , can't seem to get you a direct link...... this one...http://video.chiefarchitect.com/?search=plot+plan M. Link to comment Share on other sites More sharing options...
glennw Posted May 13, 2015 Share Posted May 13, 2015 Joe, Do you mean like this? These settings can be accessed at Defaults...CAD...General Cad. Display Line Length Format as Units = ' to how ever many decimal places you want (or different formatting if you don't want decimal feet). Display Line Angle As Quadrant Bearing. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 13, 2015 Author Share Posted May 13, 2015 Joe, Do you mean like this? These settings can be accessed at Defaults...CAD...General Cad. Display Line Length Format as Units = ' to how ever many decimal places you want (or different formatting if you don't want decimal feet). Display Line Angle As Quadrant Bearing. Thanks Glenn, That was exactly what I was looking for but I would never have thought to look at that location in Defaults. I know I must have done it sometime in the past because I have some older projects with that annotation of Property Lines. My Default Plan somehow got changed but now it's good. Link to comment Share on other sites More sharing options...
glennw Posted May 14, 2015 Share Posted May 14, 2015 Joe, The only problem is, this setting changes any existing lines. It would be good if it only applied to new lines so that you could have different lines with different formats. Link to comment Share on other sites More sharing options...
dshall Posted May 14, 2015 Share Posted May 14, 2015 Joe, The only problem is, this setting changes any existing lines. It would be good if it only applied to new lines so that you could have different lines with different formats. Absolutely Glen, and Joe, I agree that setting is so hard to find . Link to comment Share on other sites More sharing options...
Richard_Morrison Posted May 14, 2015 Share Posted May 14, 2015 Another reason to have the Plot Plan in a separate CAD detail. Link to comment Share on other sites More sharing options...
dshall Posted May 14, 2015 Share Posted May 14, 2015 Another reason to have the Plot Plan in a separate CAD detail. And I thought this was about the least important reason to do it. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 14, 2015 Author Share Posted May 14, 2015 Richard, I don't see any advantage to a CAD Detail for the Plot Plan at all. Anything that it provides can be done with an Annoset/Layerset combination. I still have to put all the Terrain Features, Dimensions, etc in the Plan View anyway. Link to comment Share on other sites More sharing options...
Richard_Morrison Posted May 14, 2015 Share Posted May 14, 2015 Display Line Length Format is set individually in CAD windows, not globally. Therefore, you can set the format to be different for a plot plan in a separate detail. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted May 14, 2015 Share Posted May 14, 2015 My property lines are always a cad box in the live plot plan, with line length turned on--no problem, I turn off the terrain perimeter in plot plan view Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 14, 2015 Author Share Posted May 14, 2015 Display Line Length Format is set individually in CAD windows, not globally. Therefore, you can set the format to be different for a plot plan in a separate detail. OK, I see that but I only show those line lengths for the Property Lines - all the others I have turned off. Link to comment Share on other sites More sharing options...
Bill_Emery Posted May 14, 2015 Share Posted May 14, 2015 When I set the defaults on floor 1 to Decimal Foot, and Quadrant bearing; the Cad Default only applies to the current floor; and not to any other floor, nor to sections and elevations. I tend to keep my plot plan live; and the CAD Default has not been a problem for me; but I don't use "show Length", and "Show Angle" for much except plot plans. One thing that has been a problem is the inability to alter the placement of the text, as sometimes thing will get crowded, or overlap. Link to comment Share on other sites More sharing options...
builtright3 Posted May 15, 2015 Share Posted May 15, 2015 My property lines are always a cad box in the live plot plan, with line length turned on--no problem, I turn off the terrain perimeter in plot plan view My new knick name for you is: "Keep IT Live Perry" I like it and I follow it! Link to comment Share on other sites More sharing options...
WendyatArtform Posted May 16, 2015 Share Posted May 16, 2015 Absolutely Glen, and Joe, I agree that setting is so hard to find . There would NEVER be a setting in Chief that makes sense only to an engineer. Oops, she said that out loud. ;-) Link to comment Share on other sites More sharing options...
