decorators3 Posted Friday at 02:05 PM Share Posted Friday at 02:05 PM Hi Most of my renderings are exterior . horizontal siding has different profiles that show well in PBR.. however Board and batten does not have any depth so is unrealistic . I was watching a You Tube video that Rene Rabbitt put up but don't know what materials he used or how the saved it So what is the best method to having a more realistic look for Board and Batten.. polylines? .. have to do a lot of cutting for windows and doors - takes time that I cant bill for Any suggestions are welcome Link to comment Share on other sites More sharing options...
Joe_Carrick Posted Friday at 02:18 PM Share Posted Friday at 02:18 PM I use another wall framing Layer (extreme exterior Layer) with 2.5" width x 3/4" thickness. It will frame with a bottom plate \ double top plate, as well as headers an sill plates. It actually creates very manageable edits - but works pretty well. I've also used Wall Material Regions but there are edits needed with that method as well. Link to comment Share on other sites More sharing options...
decorators3 Posted Friday at 02:50 PM Author Share Posted Friday at 02:50 PM 32 minutes ago, Joe_Carrick said: I use another wall framing Layer (extreme exterior Layer) with 2.5" width x 3/4" thickness. It will frame with a bottom plate \ double top plate, as well as headers an sill plates. It actually creates very manageable edits - but works pretty well. I've also used Wall Material Regions but there are edits needed with that method as well. will try for sure! thanks Link to comment Share on other sites More sharing options...
joey_martin Posted Friday at 03:01 PM Share Posted Friday at 03:01 PM I tend to use the material region tool. I create a batten and then muti-copy as needed all over the plan. 1 Link to comment Share on other sites More sharing options...
PitMan71 Posted Friday at 03:04 PM Share Posted Friday at 03:04 PM 1 minute ago, joey_martin said: I tend to use the material region tool. So you use the region to create the batten boards? Thanks Link to comment Share on other sites More sharing options...
GeneDavis Posted Friday at 03:41 PM Share Posted Friday at 03:41 PM @PitMan71 material region is the preferred way and this has been discussed in earlier threads. Do a search and find some. Then try it yourself. What is nice is that copy and repeat horizontally across an elevation places the battens quickly and trims them to gable lines and above and below all window and door openings. 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted Friday at 03:41 PM Share Posted Friday at 03:41 PM Yes, but you also need to use an exterior room molding polyline for the horizontal at the top and bottom. 1 3 Link to comment Share on other sites More sharing options...
PitMan71 Posted Friday at 03:54 PM Share Posted Friday at 03:54 PM Thanks! Link to comment Share on other sites More sharing options...
decorators3 Posted Friday at 04:56 PM Author Share Posted Friday at 04:56 PM 1 hour ago, joey_martin said: I tend to use the material region tool. I create a batten and then muti-copy as needed all over the plan. I did try it looks amazing! thanks 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted Friday at 06:46 PM Share Posted Friday at 06:46 PM 2 hours ago, Joe_Carrick said: Yes, but you also need to use an exterior room molding polyline for the horizontal at the top and bottom. Board and Batten.mp4 1 1 Link to comment Share on other sites More sharing options...
GeneDavis Posted Monday at 01:34 PM Share Posted Monday at 01:34 PM @Renerabbitthow'd you do dat? Don't be the magician with secrets. Your wall build included the top trim horizontal batten, and a base band. 1 Link to comment Share on other sites More sharing options...
RobDesLLC Posted Monday at 06:57 PM Share Posted Monday at 06:57 PM I converted a wall cabinet into a batten. I created a wall type where the sheathing is a 1/4" sheet that represents a fibercement sheet product. The batten then snaps to the wall, and I adjust the height and positioning in an elevation view. I use the multiple copy tool to distribute battens across the wall, adjusting for windows and doors as needed. This results in battens with proper shadows in renderings, and I can estimate the material used for the battens as well. I have 2 example images below to illustrate it. Link to comment Share on other sites More sharing options...
decorators3 Posted Monday at 07:20 PM Author Share Posted Monday at 07:20 PM 22 minutes ago, RobDesLLC said: I converted a wall cabinet into a batten. I created a wall type where the sheathing is a 1/4" sheet that represents a fibercement sheet product. The batten then snaps to the wall, and I adjust the height and positioning in an elevation view. I use the multiple copy tool to distribute battens across the wall, adjusting for windows and doors as needed. This results in battens with proper shadows in renderings, and I can estimate the material used for the battens as well. I have 2 example images below to illustrate it. 23 minutes ago, RobDesLLC said: I converted a wall cabinet into a batten. I created a wall type where the sheathing is a 1/4" sheet that represents a fibercement sheet product. The batten then snaps to the wall, and I adjust the height and positioning in an elevation view. I use the multiple copy tool to distribute battens across the wall, adjusting for windows and doors as needed. This results in battens with proper shadows in renderings, and I can estimate the material used for the battens as well. I have 2 example images below to illustrate it. WOW!! DID YOU USE ONLY CA FOR RENDERING Link to comment Share on other sites More sharing options...
RobDesLLC Posted Monday at 07:29 PM Share Posted Monday at 07:29 PM 7 minutes ago, decorators3 said: The first image is a 3D perspective in Chief Architect. The second is a rendering in Lumion. Link to comment Share on other sites More sharing options...
decorators3 Posted Monday at 08:15 PM Author Share Posted Monday at 08:15 PM 45 minutes ago, RobDesLLC said: The first image is a 3D perspective in Chief Architect. The second is a rendering in Lumion. I figured as much - didn't think it was rendered in CA. is Lumion or twin motion worth the investment? Link to comment Share on other sites More sharing options...
Renerabbitt Posted Monday at 09:58 PM Share Posted Monday at 09:58 PM 3 hours ago, RobDesLLC said: I converted a wall cabinet into a batten congrats on getting that done. it's a ton of work when comparing to the material region tool FYI. Hope this helps someone. Link to comment Share on other sites More sharing options...
RobDesLLC Posted yesterday at 02:44 AM Share Posted yesterday at 02:44 AM 6 hours ago, decorators3 said: I figured as much - didn't think it was rendered in CA. is Lumion or twin motion worth the investment? Yes. I have both. I use Lumion far more often for rendering images and videos, but I like the VR capability of TwinMotion, which Lumion lacks. Link to comment Share on other sites More sharing options...
RobDesLLC Posted yesterday at 02:45 AM Share Posted yesterday at 02:45 AM 4 hours ago, Renerabbitt said: congrats on getting that done. it's a ton of work when comparing to the material region tool FYI. Hope this helps someone. Thank you! I like your method. Link to comment Share on other sites More sharing options...
jtcapa1 Posted yesterday at 06:33 PM Share Posted yesterday at 06:33 PM I like the built in wall type with battens Rene. How did you do that magic? I already use your material region method but when I do, it gets messy with changes. Link to comment Share on other sites More sharing options...
decorators3 Posted 23 hours ago Author Share Posted 23 hours ago 16 hours ago, RobDesLLC said: Thank you! I like your method. 21 hours ago, Renerabbitt said: congrats on getting that done. it's a ton of work when comparing to the material region tool FYI. Hope this helps someone. I'm following your video and got it as far as EXPLODE .polyline distribution path. cant find explode in edit in 16 Link to comment Share on other sites More sharing options...
Renerabbitt Posted 23 hours ago Share Posted 23 hours ago 1 hour ago, jtcapa1 said: I like the built in wall type with battens Rene. How did you do that magic? I already use your material region method but when I do, it gets messy with changes. It's a combination of layers of custom materials that are very time consuming to put together and custom pony walls and wall coverings: 250506 (2).mp4 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted 23 hours ago Share Posted 23 hours ago 2 minutes ago, decorators3 said: I'm following your video and got it as far as EXPLODE .polyline distribution path. cant find explode in edit in 16 you would have to have a polyline distribution path with objects loaded into it and you would have to have the distribution path selected for it to show up in your edit menu Link to comment Share on other sites More sharing options...
decorators3 Posted 23 hours ago Author Share Posted 23 hours ago ok thanks 4 minutes ago, Renerabbitt said: you would have to have a polyline distribution path with objects loaded into it and you would have to have the distribution path selected for it to show up in your edit menu I see the batten in the polyline distribution path - does this look correct? Link to comment Share on other sites More sharing options...
jtcapa1 Posted 20 hours ago Share Posted 20 hours ago Rene, I have been using your material region batten method from your video. Thank you. Works great at first. After massaging the plan, it will act up in that the material regions keep vanishing. I have to turn off, then on, the material region for it to reappear again. I have to do this every time I make any change, or open or close any dialog while in 3d. Is that just me? Link to comment Share on other sites More sharing options...
jtcapa1 Posted 20 hours ago Share Posted 20 hours ago On 5/2/2025 at 7:18 AM, Joe_Carrick said: I use another wall framing Layer (extreme exterior Layer) with 2.5" width x 3/4" thickness. It will frame with a bottom plate \ double top plate, as well as headers an sill plates. It actually creates very manageable edits - but works pretty well. I've also used Wall Material Regions but there are edits needed with that method as well. Joe can you elaborate a bit more on how you made a Wall Type with "extreme exterior Layer"... what the heck is that? and your width x thickness methodology? Sounds almost like you are drawing another wall right next to the existing, Whereas Rene's secret, magic, version is an actual wall type with the upper trim and lower trim. Link to comment Share on other sites More sharing options...
