Wall Decals?
westvale
Hello,
I'm wondering if anyone has a good solution for creating wall decals.  I managed to get a half decent result with creating a new material with an image than applying that material to a wall material region.  But I'd like something that I can manipulate more easily and not have a background.  I want to put a decal on my doors and can't figure out how I would do that. Here's some images of what I'm trying to achieve:
Our Values Wall Decal 40 Awesome Signage/Wayfinding & Environmental Designs Inspiration |  Jayce-o-Yesta
For a straight decal - use create an image billboard.  BUILD>IMAGE>Create Billboard Image.
Unfortunately the sunlight is picking up the transparent billboard in the glass.  See it's shadow on the floor.
Right image is a cropping of the left's text only.
The left image has a (2) transparent cropped billboards pasted in the upper area.
All images are about a 1/4" forward of the wall you apply them to or else they fight with the wall's material.
I grabbed rabbit's images above to show how quickly they can be added to chief.
If you save the images to your library, You can apply it to a slab or 3D object, or furniture.
Below is an image of a poolhouse I recently designed. the sail painting is from the library on a 1" thick slab,  The right is actually the "waveform painting" from the library.  i changed the border to black, then changed the waveform image to a chalkboard sign image in Chief's library as well.
For me the slabs are a bit easier to manipulate than the billboards.  I sometimes use soffits too, for shower seats and 1" thick soffits painted as wall tiles,
Hope this helps.
Learn something new every day. That took me a minute Rene.  I've always had a problem with backsplashes around windows and cooktops that soffits or slabs were cumbersome to address.  I like how you can add underlying elements like thinset and backerboard to aid in material list calculations. And I can see using this to quickly to mask some of chief's 3D quirks or situations where adding skirt or molding lines are a bit cumbersome.
A minor drawback is that the dbx for slabs, soffits & 3D solids allow one to set a uniform height from floor and the width/height of those objects,  If you had door number plaques beside or on each door in a commercial office space, you could select all and change their size and location uniformly.  It seems each material region would have to be changed manually via an elevation or 3D view.  I also noticed in 3D view selecting multiples gives the highest height from floor value for all as a group, and overall width, but that isn't available when selecting just one.  Still a great feature to add to the arsenal.
Thanks. :)
You can restrictively select material regions by having material regions as the active tool and shift marquee over your entire plan in a plan view and you can use transform replicate to uniformly raise all of them in the z delta.
On 11/20/2024 at 4:04 PM, TeaTime said:
You could make the Music Note out of 3D Solids, save it as a Symbol, Hardware specifically
then apply it to the door as a Lock and adjust the symbol's Offset to move it around
That is a clever work-around.  Never would have thought of that in a million years.
Always more than one way to skin a rabb... er.. Cat. :-)
@TeaTime This took me far longer than I'd like to admit.  I had a lot of difficulty figuring out the X, Y, and X axis and the offset settings. Got there eventually! :D
I created the 3D solid by tracing the outline with a polyline.  Fairly simple for this symbol, however most of my other symbols are more complicated for that technique and it will take a very long time to create each one.  If anyone has a easier way to make the image (symbol) into a 3D solid, I'd love to hear it.
On 11/22/2024 at 1:25 PM, jtcapa1 said:
Good job. How the heck did you do that ceiling? It looks crazy.
oh yes, this ceiling was a whole thing.  I had a ton of help from a very generous and knowledgeable member of this community. The goal was to loosely recreate the original building's space frame structure, but it's not an exact replica as I am just designing the interior.
Hey Jason,
This definitely  sounds worth trying, so I searched "poster" in my library browser to try it and the only poster results I get are 4-poster beds and the periodic table of elements poster.  I tried using the poster, but I have no idea how to proceed from there. Could you explain step by step?
Sure Rene,
It's a quick tip for you, but damn you, I spent the next 2 hours I did not have watching your video, and then playing around with my logo, over and over till I got it right, then it had to go onto a wall in just the right way, highlighted just right.... Then I had to redo my logo! OMG!
It looks great, but man I have to stop watching your quick tips!
3dLogoJT.pngs
Then I could not leave well enough alone, I had to populate my fictious office
Edited by jtcapa1
Can't help myself
