Larry_Sweeney Posted December 18, 2023 Share Posted December 18, 2023 I have three railing walls exactly the same. One shows drywall on the framing and the other two don't. What determines if the drywall shows or not? I've looked at all the specifications dbx. on all three walls and everything looks the same. What am I missing? Thanks ahead for taking time for the help. Link to comment Share on other sites More sharing options...
Chrisb222 Posted December 18, 2023 Share Posted December 18, 2023 31 minutes ago, Larry_Sweeney said: I have three railing walls exactly the same. One shows drywall on the framing and the other two don't. What determines if the drywall shows or not? I've looked at all the specifications dbx. on all three walls and everything looks the same. What am I missing? Thanks ahead for taking time for the help. Just guessing since no plan file to examine, but check the railing walls' Exterior and Interior orientation. Perhaps the railing showing drywall has the Interior side facing out, and needs reversed? Also, I would not have a Drywall layer as part of a railing wall, but that's just me. Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted December 18, 2023 Author Share Posted December 18, 2023 Chris................"Orientations" are all the same on all three railing walls shown. As for the drywall material, I just "grabbed" the "interior railing" wall type and used it. I've used it many times for exterior decks and up to now the drywall never showed. I have six railing walls making up this deck and the one I show is the only one with drywall showing. I thought maybe I was missing something simple that makes it show or not. There are times when railing walls are a "three coffee cup" ordeal for me. I got the "jitters" now! Thanks for the reply. Have a great day. Link to comment Share on other sites More sharing options...
SNestor Posted December 18, 2023 Share Posted December 18, 2023 Post a plan...otherwise we are just guessing. Have you tried to create this in another simple test plan...and get different results? Link to comment Share on other sites More sharing options...
DBCooper Posted December 18, 2023 Share Posted December 18, 2023 One way to get that to happen is if you changed the "exterior wall surface" material for your railing wall. Link to comment Share on other sites More sharing options...
DeLayDesign Posted December 19, 2023 Share Posted December 19, 2023 Could be that your railing is drawn with an exterior material. My exterior deck framing is often just railing, no additional materials on the exterior, but for things like Balconies or even decks with skirting - I'll add it back in. Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted December 19, 2023 Author Share Posted December 19, 2023 Thanks guys. I'm going to be away from my computer for a day or two. When I get back I'll do more follow up with you all. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 20, 2023 Share Posted December 20, 2023 On 12/18/2023 at 2:31 PM, Larry_Sweeney said: I just "grabbed" the "interior railing" wall type and used it. I've used it many times for exterior decks and up to now the drywall never showed. The simple fix is likely to change the Walltypes of them all to the Deck/Fence Walltype, which the Straight Deck Railing Tool uses automatically ( and does not include Drywall) like the Straight (interior) Railing Tool....... and use the Deck tools for deck going forward.... * One other possibility is that your Deck Room is not specified as a deck , that can make the Drywall show too... Straight Deck Railing......... vs Straight (interior) railing M. Link to comment Share on other sites More sharing options...
