brookesdesign Posted August 16, 2023 Share Posted August 16, 2023 The skylights in X15 are great and I've been using them as solar panels as they show up dimensionally correct on the roof but they cut the hole in the roof. Is there a way to turn off the skylight from cutting the hole in the roof when using them as solar panels? Link to comment Share on other sites More sharing options...
rgardner Posted August 16, 2023 Share Posted August 16, 2023 9 minutes ago, brookesdesign said: The skylights in X15 are great and I've been using them as solar panels as they show up dimensionally correct on the roof but they cut the hole in the roof. Is there a way to turn off the skylight from cutting the hole in the roof when using them as solar panels? Any reason not to use the actual solar panel symbols in the bonus catalog instead? Link to comment Share on other sites More sharing options...
brookesdesign Posted August 16, 2023 Author Share Posted August 16, 2023 The bonus solar panel doesn't show up correctly. Its dimension doesn't follow the pitch of the roof. Link to comment Share on other sites More sharing options...
Chrisb222 Posted August 16, 2023 Share Posted August 16, 2023 1 hour ago, brookesdesign said: The skylights in X15 are great and I've been using them as solar panels as they show up dimensionally correct on the roof but they cut the hole in the roof. Is there a way to turn off the skylight from cutting the hole in the roof when using them as solar panels? Is this auto roofs? I haven't tried it, not at my computer so i can't answer your question but when working in manual roofs you should be able to delete the hole... Link to comment Share on other sites More sharing options...
brookesdesign Posted August 17, 2023 Author Share Posted August 17, 2023 I typically do manual roofs and I don't see a separate roof opening, just the skylight. I can turn off shafts and holes in the ceiling but I'm stuck with the hole in the roof. Its not a huge deal but in my sections you see the hole. Seems like this would this would be an easy option for Chief to add being solar panels are being specified more and more (at least here in Washington State). Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 17, 2023 Share Posted August 17, 2023 Why not just push CA to make the Solar Panels automatically adjust to match the roof slope? I've been asking them to do that for at least 10 years. If more users would send that feature request in (actually IMO it's a bug) then maybe it'll get done. 1 Link to comment Share on other sites More sharing options...
VHampton Posted August 17, 2023 Share Posted August 17, 2023 Sky-lites make solar panel installations a breeze. No ceiling hole. No worries. - No need for adjusting to the roof slopes either. The placement of a sky-lite (without a ceiling hole) matches the roof pitch exactly. 2 Link to comment Share on other sites More sharing options...
brookesdesign Posted August 17, 2023 Author Share Posted August 17, 2023 16 minutes ago, VHampton said: Sky-lites make solar panel installations a breeze. No ceiling hole. No worries. No need for adjusting to the roof slopes either. The placement matches the roof exactly. I agree the skylights work great for solar panels but my question is how to stop them from cutting a hole in the roof. You can turn off the hole in the ceiling but are still left with a hole in the roof. Link to comment Share on other sites More sharing options...
VHampton Posted August 17, 2023 Share Posted August 17, 2023 It’s a small trade-off. Cad tools can represent the roof rafters, or one can manually frame them (by copy/replicate) after the initial auto build. Quote Is this auto roofs? I haven't tried it, not at my computer so i can't answer your question but when working in manual roofs you should be able to delete the hole.. This here may be the very best solution if it works. Tomorrow. Test run. Link to comment Share on other sites More sharing options...
VHampton Posted August 17, 2023 Share Posted August 17, 2023 Ok. So the roof openings for sky-lites can't be turned off. The solution (to avoiding framed openings) seems to involve converting one of the solar "Sky-kites" into a symbol. Copy replicate. Done. The rafters will frame without skipping a beat. ...if there's an option for "no ceiling hole" - "no roof opening" would be a good one too. Instant solar panel feature. Link to comment Share on other sites More sharing options...
MPDesign Posted August 18, 2023 Share Posted August 18, 2023 I just tested the solar panel in the bonus MEP No.1 Energy Sources. It works as it should. It follows the pitch, the size in plan view and cross section are correct. 1 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 18, 2023 Share Posted August 18, 2023 2 hours ago, MPDesign said: I just tested the solar panel in the bonus MEP No.1 Energy Sources. It works as it should. It follows the pitch, the size in plan view and cross section are correct. This is not correct. In Plan View the 66" dimension should be 46.662". It's the projected size that is needed. Otherwise panels will overlap in Plan View. Link to comment Share on other sites More sharing options...
TeaTime Posted August 18, 2023 Share Posted August 18, 2023 5 hours ago, Joe_Carrick said: This is not correct. It is correct in that the symbol attaches flush to the roof and maintains its correct sizing. Super simple to place and resize. It is not correct in Plan, however, as you pointed out. But that's the CAD Block's fault, not the symbol. 5 hours ago, Joe_Carrick said: In Plan View the 66" dimension should be 46.662". It's the projected size that is needed. Otherwise panels will overlap in Plan View. Edit CAD Block is a great tool I'm not a fan of she skylight cutting away my roof either, but since it does it automatically for you the Skylight tool can be super handy to math the projected size for you so you know what size to make the CAD Block Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 18, 2023 Share Posted August 18, 2023 In reality, Chief should automatically adjust the CAD Block. We shouldn't have to deal with it. The 3D is automatically rotated to the correct angle. If we manually do that then "Rebuild 2D Block" will adjust the CAD Block. CA just needs to make it work. 1 Link to comment Share on other sites More sharing options...
