jbur91 Posted May 30, 2022 Share Posted May 30, 2022 Using Chief X12 and have a question about rounding. Is there a way to make dimensions round to the nearest fraction? Using the manual dimensioning tools, the program is rounding inconsistently. For example, I have my current dimension defaults set to show fractions to the nearest 1/2". However, it won't round to the nearest 1/2", it will only round down. One measurement in particular is 10'-4.94", and it's showing up on the floor plan as 10'-4 1/2" instead of 10'-5" like I want it to. This is causing exterior dimensions to appear inconsistent and is overall a huge headache for me. Is there some setting I'm not aware of that is preventing the dimensions from rounding up when I need them to? Thanks, Jack Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 30, 2022 Share Posted May 30, 2022 Edit-Default Settings - Dimensions - Primary-Smallest Fraction This can also be done to a single dimension string by opening its dialog box-Primary-Smallest Fraction, you can also have it display in fractional feet as well. DJP Link to comment Share on other sites More sharing options...
jbur91 Posted May 30, 2022 Author Share Posted May 30, 2022 David, I do have primary format of smallest fraction set to nearest 1/2 inch. Is there a setting that is preventing dimensions from ever rounding up? That appears to be my issue here. Thanks, Jack Link to comment Share on other sites More sharing options...
Chopsaw Posted May 30, 2022 Share Posted May 30, 2022 6 minutes ago, jbur91 said: I do have primary format of smallest fraction set to nearest 1/2 inch. Is there a setting that is preventing dimensions from ever rounding up? That appears to be my issue here. If you could post the plan file we could have a look at your specific situation. 1 Link to comment Share on other sites More sharing options...
VHampton Posted May 30, 2022 Share Posted May 30, 2022 Selecting the wall, and clicking on the dimension string is usually the best way to force the desired number. CAD lines can be a help as well. When placed on the same layer as manual dimensions, this method can be used to round up or down. (Placing a line on both the outer left and right exterior walls (of the foundation) is a great way to ensure that the overall dimension string adds up). One observation... many new plans (created from a template) will have "grid snaps" on by default. Usually the reference grid as well. If by chance those features are on, try turning them off. This may assist w/unwanted snapping. ...Just a wild guess... but the walls might be wanting to snap to the reference grid. Link to comment Share on other sites More sharing options...
Kbird1 Posted May 30, 2022 Share Posted May 30, 2022 16 minutes ago, VHampton said: One observation... many new plans (created from a template) will have "grid snaps" on by default. Usually the reference grid as well. If by chance those features are on, try turning them off. This may assist w/unwanted snapping. ...Just a wild guess... but the walls might be wanting to snap to the reference grid. Not always a bad idea , but it is a good idea to set the Snaps to the same as your Dimension setting eg 1/2" in this case , so walls don't snap to strange positions. Link to comment Share on other sites More sharing options...
VHampton Posted May 31, 2022 Share Posted May 31, 2022 22 hours ago, Kbird1 said: ...it is a good idea to set the Snaps to the same as your Dimension setting eg 1/2" in this case , so walls don't snap to strange positions. Agreed. Using a 1/2" grid is best right from the start. If by chance the OP had placed walls with a 12" grid however... then it's conceivable that walls could have been positioned at various increments within that 12" x 12" parameter. ...so for example, walls placed at 1/8th" or 3/4" increments would have to shift accordingly. It's a little bit of work, but that will fix everything in terms of being spot on with 1/2" dimensions - no matter which version one is working with. Link to comment Share on other sites More sharing options...
Dermot Posted May 31, 2022 Share Posted May 31, 2022 I can't think of any way to make the program round 10' 4.94" down to 10' 4 1/2'. In the picture below, I set the walls to be exactly 10' 4.94" apart. The dimension displays as 10' 5" because I have specified that they round to the nearest 1/2". If you click on the dimension, it will display the actual value as 10' 4 47/50". You should either post your plan or contact tech support. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted May 31, 2022 Share Posted May 31, 2022 34 minutes ago, Dermot said: I can't think of any way to make the program round 10' 4.94" down to 10' 4 1/2'. 10' 4.94 " is 10' 4 15/16" and with the OP's setting of 1/2" for the nearest Fraction I am not sure why it would round to 10' 4 1/2" ? ( *not sure why the OP is displaying or using decimal inches) there must be something else ( setting ?) causing that ? Unchecking Reduce Fractions in the Primary Format seems to do it though ..... it forces Dims to use the specified Fraction, so it seems it rounds up correctly in this case BUT I have not had to do that in the past? M. Link to comment Share on other sites More sharing options...
Solution jbur91 Posted June 6, 2022 Author Solution Share Posted June 6, 2022 I solved the issue! I went into my dimension default settings for my main 1/4" scale dimension defaults and changed the rounding behavior from "grid rounding" to "distance rounding." It appears that with grid rounding it will not allow itself to round up, which I needed it to do. With distance rounding, it appears to now be rounding to the nearest half inch, regardless of whether that is up or down, instead of automatically rounding down every time. Link to comment Share on other sites More sharing options...
Dermot Posted June 6, 2022 Share Posted June 6, 2022 Quote I can't think of any way to make the program round 10' 4.94" down to 10' 4 1/2'. I should have remembered this, but such is life. From the help article: Grid Rounding ensures that the sum of the parts of a dimension line add up to the whole distance. To produce this result, some sections may not be rounded accurately. This is the recommended rounding method and is selected by default. Distance Rounding addresses each section of a dimension line individually, which could result in the sum of these sections not being equal to the whole. This option is available for legacy purposes only and is not recommended. So grid rounding can round an individual value up or down so that the individual values will always add up to the overall values. If you switch to distance rounding, your dimensions may not add up and can cause problems for people trying to use them. The best way to avoid this problem is to make sure you have actually set the dimensions of your walls to what you want them to be rather than to adjust your rounding. 1 Link to comment Share on other sites More sharing options...
rgardner Posted June 6, 2022 Share Posted June 6, 2022 1 hour ago, Dermot said: The best way to avoid this problem is to make sure you have actually set the dimensions of your walls to what you want them to be rather than to adjust your rounding. Key to using Chief in general. Accuracy and build the model like you would build the structure!!! Link to comment Share on other sites More sharing options...
