JBi-PDX Posted February 16, 2022 Share Posted February 16, 2022 I'm not sure I can describe this sufficiently to make sense. I have attached two screen shots (with red text saying where the screenshot is from). In the live view elevations, everything shows up normal without any issues. Once I send the view to the layout, I get this strange diagonal line showing up. This shows up in 3 elevations out of 30. There doesn't appear to be any commonality between the two rooms that might cause this weird line - no strange wall intersections, etc. Any thoughts anyone? Thanks, in advance. Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 16, 2022 Share Posted February 16, 2022 The lines are either on a layer that is on that you may be able to turn off or you can delete the lines after the view is sent to layout using the "Edit layout Lines Tool" . DJP Link to comment Share on other sites More sharing options...
SusanC Posted February 16, 2022 Share Posted February 16, 2022 Does this happen if you send the elevations to layout as plot lines instead of live views? I had some odd issues happening with my Mac and live views and the help desk had me try sending elevations to layout as plot lines rather than live. Took care of my problems. Link to comment Share on other sites More sharing options...
JBi-PDX Posted February 16, 2022 Author Share Posted February 16, 2022 @DavidJPotter - I was able to remove the lines using the "edit layout lines" tool. However, if I go back into the elevation to make edits, the lines appear again. They aren't a line that I've drawn, so that's why it's confusing. @SusanC - I looked at these elevations in live view and they don't show up. As soon as I went back to plot lines, they showed up again. I always use plot line view for elevations. I find they look better. Link to comment Share on other sites More sharing options...
Greg_NY61 Posted February 16, 2022 Share Posted February 16, 2022 Post a plan Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 16, 2022 Share Posted February 16, 2022 I have this happen all the time when sending as Plot Lines. I keep forgetting to report it. I always just delete them. I'll report it right now. You should as well. Link to comment Share on other sites More sharing options...
rgardner Posted February 16, 2022 Share Posted February 16, 2022 Pretty sure you are sending as a live view and it is showing the pixelation of the picture but if you are sending as plot lines then report it as Michael says. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 17, 2022 Share Posted February 17, 2022 14 hours ago, JBi-PDX said: I get this strange diagonal line showing up This was a known Issue in earlier Versions of X13 but is fixed in the latest release....... however your Sig. says you are using X12 , and I did not have the issue in x12. M. Link to comment Share on other sites More sharing options...
