Scotbow Posted May 3, 2021 Share Posted May 3, 2021 I'm working on a design with some sloping walls, (inside & out), similar to the attached pics. Is there a simple way to accomplish this? Thanks in advance. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 3, 2021 Share Posted May 3, 2021 NO Link to comment Share on other sites More sharing options...
Chopsaw Posted May 3, 2021 Share Posted May 3, 2021 Are the walls sloping or just the timber frame ? Very nice design but challenging build. Link to comment Share on other sites More sharing options...
GeneDavis Posted May 3, 2021 Share Posted May 3, 2021 It will take time, but the tilted elements can all be modeled as solids. For just those parts, I'd be inclined to model in Sketchup and import. CDs will be tedious. Charge a fortune. Link to comment Share on other sites More sharing options...
Scotbow Posted May 3, 2021 Author Share Posted May 3, 2021 I was hoping an update had made things easier. All the other posts, I saw, were older. Thanks Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 3, 2021 Share Posted May 3, 2021 The problem is that Chief's walls are specifically designed for Doors (and Windows) that need to be vertical. There are no provisions for anything else. Chief simply doesn't cater to walls that are not vertical. As Gene said, you could use Solids but that won't work to define a room - only "Walls" provide that functionality in Chief. Link to comment Share on other sites More sharing options...
Gawdzira Posted May 4, 2021 Share Posted May 4, 2021 I also would model this with solids. But, to establish rooms, you could make invisible walls at the low point of the sloping wall and get a fairly good plan view representation. For sections, it is cad lines. Link to comment Share on other sites More sharing options...
glennw Posted May 4, 2021 Share Posted May 4, 2021 In some instances, you may be able to get away with creating a symbol. Get your vertical wall set up the way you want, select it and then use Convert Selected to Symbol. The symbol will contain the wall, doors and windows. Rotate the symbol. You may have to make the wall taller than normal to allow for the loss of height due to the slope. Link to comment Share on other sites More sharing options...
