RaquelPorlamar 0 Posted November 4, 2020 Hi I'm trying to figure out how to finish this shape room ... I need the roof all over to match and a skylight window on the slanted ceiling plane side, Thank you using CA X12 premier Share this post Link to post Share on other sites
steve_stuart 11 Posted November 4, 2020 You can use a roof plane instead of a ceiling plane and insert the skylight. You will need to adjust the baseline height of the roof plane down to get the ceiling inside where you want it. Share this post Link to post Share on other sites
LDuncan 0 Posted January 12 Raquel, I am trying to build a bathroom with the same flat ceiling to slanted ceiling - just like you have above. I am new at this, and I have watched numerous videos on walls and ceilings. But I can't for the life of me figure out how to create this. could you please give me some direction on how to create the wall/ceiling structure? Thank you, Leslie Duncan Share this post Link to post Share on other sites
solver 1578 Posted January 12 @LDuncan Please check your messages, and tell us what you are unable to figure out. Do you understand how to use a roof or ceiling plane to create the sloped ceiling? Share this post Link to post Share on other sites
Electromen 51 Posted January 12 Build your roof first, then building the sloped ceiling using ceiling planes. Set the base of the sloped ceiling at the same height at the top plate of the wall. Experiment, you may need to set the base an inch or 1 1/2" higher. Set the top of the slope at the flat ceiling height Share this post Link to post Share on other sites
glennw 992 Posted January 12 Set the room ceiling height to the hight where the sloping ceiling meets the external wall. Auto build the roof - it will build off that low ceiling height. Turn off auto build roofs Uncheck Flat Ceiling Over This Room Change the ceiling height to the height of the flat section of roof Click OK Check Flat Ceiling Over This Room Place your skylight in the roof. 1 Share this post Link to post Share on other sites
Mark3D 39 Posted January 12 maybe this file will help you roof skylight.plan Share this post Link to post Share on other sites
glennw 992 Posted January 12 Mark's way is different to mine. Mine used a single roof slope over the whole room (a shed roof) with flat ceiling on the upper part of the roof - resulting in an attic space above the flat ceiling. Mark used 2 different roof slopes to get the 2 ceiling planes with the ceiling planes following the roofs. Pick your poison. And the good thing is that there is usually more than 1 way to do something in Chief. Share this post Link to post Share on other sites
GeneDavis 134 Posted January 12 The challenge is when you want the skylight shaft wall at the lower side to be aligned to the wall below. A continuation of that wall right up to the skylight curb. Share this post Link to post Share on other sites
LDuncan 0 Posted January 12 Thank you all for your help and suggestions. I have some homework to do. Leslie X12 - Interiors New user. Share this post Link to post Share on other sites
Alaskan_Son 2473 Posted January 13 12 hours ago, LDuncan said: Thank you all for your help and suggestions. I have some homework to do. Leslie X12 - Interiors New user. Bear in mind that some of the advice above may or may not help you if you're using Interiors. The roof tools in Interiors are a bit more limited. Share this post Link to post Share on other sites
