akabuilder
Footers under basement slab
I've got a 3 story house with 8' high basement,  8in. high footers (12" wide) sitting under Fox Block walls with a slab foundation. Can anyone offer a solution or explanation as to why the footers are not sitting directly underneath the basement slab on the elevation view? They look like they are running into the slab....
You have complete control -- just change settings as needed to place them as required.
Measure in 2D section, adjust stemwall height in the basement room dialog.
What's your stem wall height compared to the ceiling height.  The stem height (room dbx) should be rough ceiling height plus your slab thickness.
2 hours ago, mtldesigns said:
The stem height (room dbx) should be rough ceiling height plus your slab thickness.  (minimum)
Agreed - looks like the issue to me too....
The footing will be placed directly under the foundation wall, NOT the slab. This means that for clean and neat alignment in Chief, the top-of-footing elevation needs to match the bottom-of slab elevation. Chief doesn't currently 'support' a notched basement slab. For your model, you have essentially 2 options:
  • adjust either the foundation wall height or the basement slab elevation to produce a clean intersection
  • leave it 'as is' and clean up the display in section views using CAD tools
FWIW, I frequently do both, dependent on the construction preferences of my clients.
Thanks I will try this....Adjusting my dimensions hopefully will fix this - a clean intersection is what I want.
A good trick to reset the stemwall height is to set it to 0 and press tab.  (don't be scared, funny stuff will happen)
Then go back up and re-enter your rough ceiling height.
The stemwall will automatically adjust to the proper height without requiring any calculation on your behalf.
    28870
    ChiefJeet
    ChiefJeet
