C-HisBuilders Posted October 12, 2020 Share Posted October 12, 2020 I am using Chief Architect x10 in an office where we do both the designing and the building. We are trying to determine if there is a way to have the window schedule show the actual size of the window glass. On the model we draw the window to the rough opening size because that is what we want to see on the floor plan. I see that you can have the window add dimensions to each side as a R/O, but since that is not what shows on the floor plan, that is not helpful to us. Is there a way to calculate the smaller opening of the glass or a way to have the floor plan show the window with the additional dimension of the R/O? Link to comment Share on other sites More sharing options...
DzinEye Posted October 12, 2020 Share Posted October 12, 2020 2 minutes ago, solver said: I placed a default window and 2 dimension strings, one set to locate sides, one to locate rough opening. I think the OP want's dimension to inside of sash (exposed glazing area) Link to comment Share on other sites More sharing options...
GeneDavis Posted October 13, 2020 Share Posted October 13, 2020 I can see that in a table, maybe, for somebody's idea of energy calcs, or for some other reason, but on the drawings, for building? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 13, 2020 Share Posted October 13, 2020 This can be done with a macro(s) and custom field(s). Typically I would put that information in the Window Schedule. Link to comment Share on other sites More sharing options...
C-HisBuilders Posted October 13, 2020 Author Share Posted October 13, 2020 1 hour ago, Joe_Carrick said: This can be done with a macro(s) and custom field(s). Typically I would put that information in the Window Schedule. I keep trying to think of how to explain this so it is not confusing! But yes, it is going in the window schedule. It is for the actual construction of the building and purchasing of the windows. Great idea to look into the macros. I thought of using a custom field but am not sure I want to manually enter information on so many windows that may have to be changed, it's nice to have the program features that change based on the width/height entered. Link to comment Share on other sites More sharing options...
jmsisco Posted October 13, 2020 Share Posted October 13, 2020 Not sure exactly what you are after? What about just displaying the RO on the window Schedule? Link to comment Share on other sites More sharing options...
C-HisBuilders Posted October 13, 2020 Author Share Posted October 13, 2020 What is the macro "Formatted Opening Width" pulling from? I can't figure out what is creating the number it spits out. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 13, 2020 Share Posted October 13, 2020 It would be best if you were to post an example of exactly which measurements you're looking for. Maybe a sketch of the window, how it displays in the schedule now, and how you would like it to display. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 14, 2020 Share Posted October 14, 2020 20 hours ago, C-HisBuilders said: Great idea to look into the macros. I thought of using a custom field but am not sure I want to manually enter information on so many windows that may have to be changed, it's nice to have the program features that change based on the width/height entered. If the macros are written correctly and the custom fields are created then it's a simple matter to select all the windows and add the macro to that field in the Object information. If any window is modified, the data reported by the macros would automatically be updated with the appropriate values. Link to comment Share on other sites More sharing options...
C-HisBuilders Posted October 14, 2020 Author Share Posted October 14, 2020 3 hours ago, Joe_Carrick said: If the macros are written correctly and the custom fields are created then it's a simple matter to select all the windows and add the macro to that field in the Object information. If any window is modified, the data reported by the macros would automatically be updated with the appropriate values. Thanks all for trying to help. I am going to watch a few videos on creating macros because that seems to be the solution to my issue. I want the system to calculate a measurement for me and not have to type it and adjust it every time. I appreciate all you trying to figure out how to help me! Link to comment Share on other sites More sharing options...
C-HisBuilders Posted October 14, 2020 Author Share Posted October 14, 2020 7 minutes ago, solver said: We could be more helpful if you tell us what measurement you want the system to calculate. I want to enter the R/O as the size of the window and have the system calculate the net size of the window (the glass size). Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 14, 2020 Share Posted October 14, 2020 10 minutes ago, C-HisBuilders said: I want to enter the R/O as the size of the window and have the system calculate the net size of the window (the glass size). I'm assuming you really mean net unit size and not glass size. If I'm understanding correctly, in order to get an accurate model and use the built in features, you may be better off entering the net size and using the rough opening settings appropriately. Then you can simply use the Height, Width, and R/O columns in the schedule. No need for any custom macros at all that way. 1 Link to comment Share on other sites More sharing options...
GeneDavis Posted October 14, 2020 Share Posted October 14, 2020 Why not refer to the window schedule, which can be formatted to show both unit size WxH and R.O. size WxH. You can draw your plans to dimension to R.O. Where I am, the suppliers send a guy to your jobsite when you have built most or preferably all your R.O.s, and he carefully checks them against his quote and your window schedule he quoted from. Only then does the release to to the factory to build the windows. 1 Link to comment Share on other sites More sharing options...
cajunland Posted October 22, 2020 Share Posted October 22, 2020 In as-built I need to replace existing window with a smaller height new one. Window supplier asks me the following: Is it new construction or remodel? Need to determine if we use nominal versus actual size for the window. Window remodel contractor wants a completely framed RO w/Header and also a finished opening/sheathing exterior over that framing to be able to measure for exact fit w/1/8" variance. *I note that Genes advice will apply in any case. My thinking for my as-built: Assumption #1- is that "net unit size" stated by Michael means same as the CA Reference Manual X12- Window Specification Dialog- GENERAL- Size and Position: Width: Height: ex. "These values include the window frame." Assumption #2- So if you know size the window is manufactured to (window & frame) then correct RO and header will be automatically generated by CA. For as-built I measure 35" x 59" inside window dimensions. So, I may want to show window as an actual "standard size" 36" x 60" in Window Spec/General. Unless I can find out actual size. Link to comment Share on other sites More sharing options...
GeneDavis Posted October 22, 2020 Share Posted October 22, 2020 Define "glass size." Every window manufacturer has charts for the glazing area of their windows, but a double hung with unit size W x H from Andersen can have a different glazing area from Marvin for the same double hung type of same size W x H. I think you are using glass to say what most would call unit. Link to comment Share on other sites More sharing options...
jonow6 Posted October 22, 2020 Share Posted October 22, 2020 On 10/14/2020 at 12:03 PM, solver said: Using this double hung window for example, you want the area of the glass as shown by the red outlines? How would you get the glazing area?.. Link to comment Share on other sites More sharing options...
MoeGia Posted October 23, 2020 Share Posted October 23, 2020 You should get the glazing area from the window manufacturer. Glass area is dependent on how they build their windows. I would not scale this number off a Chief window unless you model the window and sash exactly as the manufacturer builds it. Too much liability; get the number from the manufacturer. Link to comment Share on other sites More sharing options...
