80238dmcm Posted September 2, 2020 Share Posted September 2, 2020 I seemed to have lost my user catalog. I cannot figure out what happend. Are these backed up? Can I reload it? Link to comment Share on other sites More sharing options...
Renerabbitt Posted September 2, 2020 Share Posted September 2, 2020 32 minutes ago, 80238dmcm said: I seemed to have lost my user catalog. I cannot figure out what happend. Are these backed up? Can I reload it? Do a system wide search. if you are on a PC, type "ext: .calib" without quotes in your file explorer search bar Link to comment Share on other sites More sharing options...
Kbird1 Posted September 3, 2020 Share Posted September 3, 2020 Should maybe call Tech support in the morning , but if you haven't backed it up , then the usual location in listed in Preferences>Folders>User Library Folder> the KEEP section , will have it's last location....... *** and for anyone else who reads this, a reminder go to your Library and Export the User Catalog regularly to a safe place like an Ext. Hard drive just in case. KB Article on how to.... https://www.chiefarchitect.com/support/article/KB-00091/backing-up-and-restoring-library-content.html Link to comment Share on other sites More sharing options...
80238dmcm Posted September 3, 2020 Author Share Posted September 3, 2020 On 9/2/2020 at 4:09 PM, Renerabbitt said: Do a system wide search. if you are on a PC, type "ext: .calib" without quotes in your file explorer search bar thanks for the suggestion.. they appear to be gone..gone..gone.. but I'll keep trying Link to comment Share on other sites More sharing options...
Electromen Posted September 4, 2020 Share Posted September 4, 2020 2 hours ago, 80238dmcm said: thanks for the suggestion.. they appear to be gone..gone..gone.. but I'll keep trying Back UP UP UP Link to comment Share on other sites More sharing options...
chipporter Posted December 18, 2020 Share Posted December 18, 2020 My user catalog folder is there but it's empty. We live in a modern world. This just should not be an issue when using a program that automatically does backups while you are working. Nothing worse than hearing about what you should have done after its too late. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 18, 2020 Share Posted December 18, 2020 6 hours ago, chipporter said: My user catalog folder is there but it's empty. We live in a modern world. This just should not be an issue when using a program that automatically does backups while you are working. Nothing worse than hearing about what you should have done after its too late. The User Catalog is not covered by the Autobackup system , that is your responsibility , I would suggest you call Tech. Support and see if they can help recover it. M. Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 18, 2020 Share Posted December 18, 2020 What I have adopted is to triple back up everything which is what my additional hard drives and my One Drive accounts are for. Library files I manually back up and update manually when I add new library files which I back up to a USB hard drive for that purpose, just saying... BTW if you like, I can share my own personal "Users Library" file, it has symbols in it dating back to Noah's Ark, it is about one and a half GB in size to replace your missing one, let me know DJP Link to comment Share on other sites More sharing options...
MiseDesign Posted October 20, 2023 Share Posted October 20, 2023 I am having that same issue now too. I got a new computer and that file now has no data in it. It can find it, but nothing to download. I'll take the "Noahs Ark" file if this gets fixed. Link to comment Share on other sites More sharing options...
DBCooper Posted October 20, 2023 Share Posted October 20, 2023 If you got a new computer, then your user library should still be on your old computer but it won't be transferred over to your new computer automatically. If your old computer is still running, then you can still make a backup of your user library and then transfer it to your new computer. If your old computer died but you made a backup of your user library at some time, then you should be able to restore it but you may lose everything you made since your last backup. If your old computer died and you didn't make any backups, then you are probably out of luck. The only thing that might help you is if your hard disk is still functioning well enough to extract the data that might be still on it. The only other thing that might help is that if you have any backups of your plan files that are using things from your user library, you can always open the plan and then add these objects back to your new user library. This can be pretty tedious when you have custom objects spread out through lots of old plans. The bottom line is that you should make regular backups of anything you don't want to lose. Here is a tech article explaining how to backup everything: https://www.chiefarchitect.com/support/article/KB-00001/backing-up-chief-architect-content.html Here is the article explaining how to restore everything that you have backed up: https://www.chiefarchitect.com/support/article/KB-00091/restoring-chief-architect-content.html Link to comment Share on other sites More sharing options...
Chrisb222 Posted October 20, 2023 Share Posted October 20, 2023 6 hours ago, MiseDesign said: I am having that same issue now too. I got a new computer and that file now has no data in it. It can find it, but nothing to download. I'll take the "Noahs Ark" file if this gets fixed. Make sure it wasn't moved to a non-standard location. From Support: If the Chief Architect Premier Data folder is renamed, moved or deleted, the program will automatically replace it using default information from the program's installation folder. When this occurs, customized user settings and custom user library content will not be available. Link to comment Share on other sites More sharing options...
