Mtommo Posted May 5, 2020 Share Posted May 5, 2020 I am trying to insert an interier rectangle Brick pillars, four in total, size 360mm x 250mm in my games Room which the middle two would be the entrance to the games Room, I can't seem to find any in Chief Architects Library, does anyone know if this is at all possible? Mike Link to comment Share on other sites More sharing options...
robdyck Posted May 5, 2020 Share Posted May 5, 2020 A simple rectangle, or with a cap and base? Either way, you can do this quite easily using the polyline solid tools. Start to drag out a polyline solid, before letting go of the mouse, hit tab, enter your 360 x 250 dimensions. Then open the object, and specify its height, elevation relative to floor, layer, and material. Link to comment Share on other sites More sharing options...
tommy1 Posted May 5, 2020 Share Posted May 5, 2020 You could also use walls or even a slab. Kinda depends on the situation. Link to comment Share on other sites More sharing options...
rgardner Posted May 5, 2020 Share Posted May 5, 2020 So many ways. posts, polyline solids, slabs, walls, moldings, etc... Link to comment Share on other sites More sharing options...
HumbleChief Posted May 5, 2020 Share Posted May 5, 2020 ...cabinet would be my choice, saved to library as a symbol? Link to comment Share on other sites More sharing options...
Ridge_Runner Posted May 5, 2020 Share Posted May 5, 2020 4 hours ago, HumbleChief said: ...cabinet would be my choice, saved to library as a symbol? Also easier in many cases to add the moldings, if wanted, for the top and bottom trim when using a cabinet. Link to comment Share on other sites More sharing options...
Dermot Posted May 5, 2020 Share Posted May 5, 2020 Quote So many ways... In addition to the things already mentioned above: - 3D box primitive - there is a "Closed Box" in the shapes library - the ever versatile soffit - custom counter top - floor material region - landing - and if you feel clever, you could even use a terrain feature but you will have to turn off the building hole to see it in the house. - and if you really like working harder than you need to, you could create one just using 4-6 3D face primitives. - and if you really, really like working hard, you could probably create a brick symbol and stack them up one by one (but if you want realistic mortar, it's going to be even more work). Maybe we should have a contest to see who can come up with the strangest way to create this? 1 Link to comment Share on other sites More sharing options...
DzinEye Posted May 5, 2020 Share Posted May 5, 2020 45 minutes ago, Dermot said: Maybe we should have a contest to see who can come up with the strangest way to create this? Hmm... that could be to build a solid the size of the entire room, then use solid subtraction to remove everything but the columns. Link to comment Share on other sites More sharing options...
