kwhitt Posted March 3, 2020 Share Posted March 3, 2020 Mark - I thought you might have a clever way of building this run of wall cabinets in one piece. I was able to fake it by reducing the stiles where the cabinet over the hood connects to the adjacent cabinets. Can this be done in one piece? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 3, 2020 Share Posted March 3, 2020 No, but you could block those and convert to a symbol. Link to comment Share on other sites More sharing options...
SNestor Posted March 3, 2020 Share Posted March 3, 2020 Why would you want to build as "one piece"? 1 Link to comment Share on other sites More sharing options...
joey_martin Posted March 3, 2020 Share Posted March 3, 2020 On 3/3/2020 at 7:05 PM, SNestor said: Why would you want to build as "one piece"? Expand Yes...inquiring minds want to know. 1 Link to comment Share on other sites More sharing options...
kwhitt Posted March 3, 2020 Author Share Posted March 3, 2020 On 3/3/2020 at 7:05 PM, SNestor said: Why would you want to build as "one piece"? Expand It's mostly out of curiosity, however custom face frame cabinets are built this way all the time in our market to avoid seams between the frames. Our shop will do this especially if they're inset. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 3, 2020 Share Posted March 3, 2020 Totally doable... One piece cab example.planFetching info... ...and we have also commonly built cabinets in one piece to get rid of unnecessary stiles, rails, and redundant case work, so I completely understand why you would want to do so. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 3, 2020 Share Posted March 3, 2020 NOTE: I didn't finish the cabinet. Just took it far enough so that you understood what was going on. Next step would be to add separations (or shelves) for the bottom of the 2 side sections and to change the back to something solid (Blank Areas or similar). Link to comment Share on other sites More sharing options...
MarkMc Posted March 3, 2020 Share Posted March 3, 2020 On 3/3/2020 at 6:42 PM, kwhitt said: Can this be done in one piece? Expand 3 cabinets- center cabinet has 0" width stiles. Not worth the hoops you have to jump to get the bottom of the center section to stay open -pretty much how those are built. IF it's really important to you-build the 3 cabinets, convert to cabinet door symbol and place in a blank cabinet. (cabinet on right is that way) A cad elevation will be far better using the 3 cabinets, if you need both good cad and good schedule you could use both :)))) 2 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 3, 2020 Share Posted March 3, 2020 On 3/3/2020 at 9:33 PM, MarkMc said: 3 cabinets...Not worth the hoops you have to jump to get the bottom of the center section to stay open Expand For the record, I agree, and this is the basic approach I typically use myself. I almost always build those combined units out of several cabinets. I was only offering a way that it could be done with a single cabinet. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 3, 2020 Share Posted March 3, 2020 By the way, the bottom part of the 2 side sections is tricky and requires some custom shelf symbols if you want them to be part of the cabinet itself (as opposed to manually positioned and free floating) but it's still totally doable. Not something I have time to go through in great detail, but here's a rough finished example... One piece cab complete.planFetching info... I didn't perfect all the specifics. Just enough to get the point across. Link to comment Share on other sites More sharing options...
kwhitt Posted March 4, 2020 Author Share Posted March 4, 2020 On 3/3/2020 at 7:23 PM, Alaskan_Son said: Totally doable... One piece cab example.planFetching info... ...and we have also commonly built cabinets in one piece to get rid of unnecessary stiles, rails, and redundant case work, so I completely understand why you would want to do so. Expand Thanks Michael! Link to comment Share on other sites More sharing options...
kwhitt Posted March 4, 2020 Author Share Posted March 4, 2020 On 3/3/2020 at 9:33 PM, MarkMc said: 3 cabinets- center cabinet has 0" width stiles. Not worth the hoops you have to jump to get the bottom of the center section to stay open -pretty much how those are built. IF it's really important to you-build the 3 cabinets, convert to cabinet door symbol and place in a blank cabinet. (cabinet on right is that way) A cad elevation will be far better using the 3 cabinets, if you need both good cad and good schedule you could use both :)))) 3 cabs.planFetching info... Expand Thanks Mark Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 4, 2020 Share Posted March 4, 2020 On 3/4/2020 at 3:28 PM, kwhitt said: Thanks Michael! Expand You bet. Here's another quick example of an option where the bottom side of those side units is actually part of the cabinet and not added to the unit as a shelf from the library... One piece cab complete 2.planFetching info... 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 4, 2020 Share Posted March 4, 2020 My solution is a little different: 2 standard framed (or unframed) cabinets 1 center unframed cabinet (sides are normal) select all three and convert to interior furnishings symbol (hangs on wall with appropriate height) add to schedule as "Wall Cabinet"c Make sure you edit the label and description to show what you want in the Schedule. 1 Link to comment Share on other sites More sharing options...
kwhitt Posted March 5, 2020 Author Share Posted March 5, 2020 On 3/4/2020 at 3:32 PM, Alaskan_Son said: You bet. Here's another quick example of an option where the bottom side of those side units is actually part of the cabinet and not added to the unit as a shelf from the library... One piece cab complete 2.planFetching info... Expand Thanks again for all the tips! Link to comment Share on other sites More sharing options...
