gmdesigns45 Posted August 23, 2019 Share Posted August 23, 2019 how can I place 2 sinks in 1 vanity cabinet Link to comment Share on other sites More sharing options...
gmdesigns45 Posted August 24, 2019 Author Share Posted August 24, 2019 Thank you Link to comment Share on other sites More sharing options...
NateGeno Posted December 27, 2019 Share Posted December 27, 2019 I'm creating a vanity sink base, 60" wide with a drawer base in the middle. The counter top will only allow one sink as part of the cabinet. I can place an additional sink in the top and it looks fine in both plan and elevation views. However, when I pull the cabinet into a schedule the elevation in the schedule will show only the one sink. Also, when I save the cabinet into the library it will also only save the cabinet with one sink. My question- how would I create and save the cabinet with two sinks? Link to comment Share on other sites More sharing options...
Evolution Posted December 27, 2019 Share Posted December 27, 2019 Assuming you are making an architectural block from the cabinets, before adding to the library? Link to comment Share on other sites More sharing options...
NateGeno Posted December 27, 2019 Share Posted December 27, 2019 Thank you for the reply. That doesn't seem to work, either. Evidently, I would need to be able to "place" two sinks in the same top in order for the second sink to be accepted in the object. I can make this correct in the plan, but, it doesn't save into the library correctly. More importantly, it doesn't show in the elevation view of the cabinet schedule correctly. I'm currently using X11. Link to comment Share on other sites More sharing options...
MarkMc Posted December 27, 2019 Share Posted December 27, 2019 31 minutes ago, NateGeno said: That doesn't seem to work, either. Read up on arch blocks, schedules and the OIP (object information panel) fields. Open everything that is included in plan-everything. two sink vanity.plan 2 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 27, 2019 Share Posted December 27, 2019 Depending on what you need, whether or not you're making heavy use of the material list and/or fixture schedules, and how adept you are at the tools, you can also create a single custom symbol that includes both sinks. here's a quick example that has both sinks in a single cabinet without having to create a block... Base Cabinet w Sink Pair.calibz 2 Link to comment Share on other sites More sharing options...
rgardner Posted December 28, 2019 Share Posted December 28, 2019 Similar version at 21" depth SB6021R Dbl Sink Vanity.calibz 1 Link to comment Share on other sites More sharing options...
NateGeno Posted December 30, 2019 Share Posted December 30, 2019 Thank you all for your help. 1 Link to comment Share on other sites More sharing options...
Electromen Posted December 31, 2019 Share Posted December 31, 2019 I use two 24" W x 21" D cabinets with a 12" W x 21" D drawer base in the center. Then place sinks in the 24" bases. Link to comment Share on other sites More sharing options...
GeneDavis Posted December 31, 2019 Share Posted December 31, 2019 What is the blocking about? I drew a single basecab, edited it to 72 width, fiddled with the front specs to get a 28 wide opening at each end, placed a sink, moved it away from center, placed a second sink freestanding and moved it into place, and I think I am done. Did not do the work to edit the stack at the center into a 3 or 4-drawer array, but the sinks are there where needed. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 31, 2019 Share Posted December 31, 2019 The main goal (at least the challenge I was personally trying to help solve) was to get a SINGLE cabinet for material lists and schedules (something that a block somewhat solves), and to get 2 sinks that BOTH show in schedule images and that BOTH carry with the unit when it’s added to the library (something that the block also solves). The block has various problems and the double sink symbol method also has various problems, but they solve the challenge that was posed by NateGeno (not the OP). Link to comment Share on other sites More sharing options...
rgardner Posted December 31, 2019 Share Posted December 31, 2019 10 minutes ago, GeneDavis said: What is the blocking about? I drew a single basecab, edited it to 72 width, fiddled with the front specs to get a 28 wide opening at each end, placed a sink, moved it away from center, placed a second sink freestanding and moved it into place, and I think I am done. Did not do the work to edit the stack at the center into a 3 or 4-drawer array, but the sinks are there where needed. When you select it does it show two sinks? And with the material list as well? Only worked with me when I made a double sink and input it as one. Link to comment Share on other sites More sharing options...
Electromen Posted December 31, 2019 Share Posted December 31, 2019 Are your cabinets custom made to size? Link to comment Share on other sites More sharing options...
GeneDavis Posted January 1, 2020 Share Posted January 1, 2020 OK I get the blocking. I don't do these as a single unit, so the single-cab thing isn't something I'd do. Wouldn't one just do a comment about two sinks in the cab schedule? My plans don't specify or schedule out plumbingware, so I guess I just didn't understand the specifics here. Link to comment Share on other sites More sharing options...
rgardner Posted January 1, 2020 Share Posted January 1, 2020 34 minutes ago, GeneDavis said: OK I get the blocking. I don't do these as a single unit, so the single-cab thing isn't something I'd do. Wouldn't one just do a comment about two sinks in the cab schedule? My plans don't specify or schedule out plumbingware, so I guess I just didn't understand the specifics here. personally I generally would do three cabinets there for most of my builders as they are buying box cabinets and it’s pretty difficult to get that large of cabinet around hallways and upstairs in some cases. But I have done ones this size for custom cabinet manufacturers. Although the note regarding double sink base would work I tend to do a schedule with a 3d preview so it makes it more accurate and precise to show the two sinks and removes one more possible chance for error on ordering. Link to comment Share on other sites More sharing options...
MarkMc Posted January 1, 2020 Share Posted January 1, 2020 3 hours ago, rgardner said: personally I generally would do three cabinets there for most of my builders as they are buying box cabinets and it’s pretty difficult to get that large of cabinet around hallways and upstairs in some cases. But I have done ones this size for custom cabinet manufacturers. No need for custom cabinets to get one of these. These are even available in an inexpensive builder grade brand like Merrilat Classic as well as every semi custom box mfg I know of. If buying off the shelf you might need to use 3 cabinets required but the local box store even has a 60" in stock It's easier to move around than typical tall cabinet or a lazy suzan, I've never had an issue. At the same time a single cabinet will typically costs less than using 3 cabinets (50% in one brand I just checked), slightly increases usable storage, and is faster to install. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 1, 2020 Share Posted January 1, 2020 2 minutes ago, MarkMc said: At the same time a single cabinet will typically costs less than using 3 cabinets (50% in one brand I just checked), slightly increases usable storage, and is faster to install. Also uses less material so it’s less wasteful and they almost always look a lot nicer since they don’t have unnecessary seams. Having cabinet shop build groups of potentially separate cabinets into single units also allows for a lot of configurations that would otherwise be super inefficient or even impossible. It’s something we’ve done a lot. Link to comment Share on other sites More sharing options...
duright1 Posted January 6, 2020 Share Posted January 6, 2020 Thanks Chiefs user this will help . Link to comment Share on other sites More sharing options...
