Plan View Equipment Questions
ACADuser
I have a large building with some 80+ rooms that need the equipment, furniture etc. displayed in plan view.
The equipment does not need to be 3D. I was building 2D plan view of each in Autocad because it is much faster for me to create the blocks.
I was going to import them into Chief as a block & fill the rooms. In Autocad I can add info to the blocks as attributes "smart text" and hidden descriptions.
But Chief does not support extra info attached to the block. The goal is to have a room by room inventory list &  call outs like the attached picture.
If I used 3D objects I fear the plan would be overloaded (too slow) & besides I don't want to create or chase down all the 3D objects.
Any suggestions as to a strategy for this task?
I could create a simple object & make into a symbol & then assign my 2D block to it.
The symbol does support additional information.
Then perhaps a room material list or fixture list, just any report that can be dome room by room.
Expand
This would be my approach, why not make it 3d so you can just use a fixture schedule and custom fields etc plus have the benefit of correct elevations etc. not to mention macro implementation/object info etc. Just use a library symbol that is similar and designate your cad block to that symbol
Thanks Bill,
So the notes will provide the info.
This project has 84 notes already & is a bit slow.
Adding another schedule with 26 notes per room (not all rooms) will surely slow the plan down.
So 25 notes in 50 rooms is 1250 notes!
Can you report notes "By Room"?
@ACADuser
If you want to avoid 3d  I like your idea of a 'simple symbol'. I recently did a timber component plan and I used notes to schedule it. I didn't like it because the note has no direct correlation to the object. However keep in mind that notes are really the only choice we have for compartmentalizing schedules. Your simple symbols will become 'fixtures' and I don't think you can pick and choose fixture types for schedule reporting. They're either in or out. They should be layer controlled along with their labels, or like notes, allow us to create our own types of fixtures.
Not an easy decision! Let us know how you choose to proceed.
I do a lot of commercial work and try to get 3D symbols for as much as I can.  However, in a pinch, I have created squares and circles, convert to 3d, then make a symbol.  I have put them both in equipment and furniture categories.   Copy and paste, change size and modify the descriptions etc.  Works like a charm.
Thanks all.
I am able to use SketchUp Free version to separate the objects.
Saving each item to a SKP file & then importing into Chief.
I'm not very good at this process, yet. Just realized all should be imported as Fixtures, interior, not Furnishings.
Back to work.
