Stone material/River Rock, Pebble Stone
jjifmeyer
Maybe "its" in a catalogue? Which It? The Border?  I don't think there is any available in CA X10 library, but you can  make it. I assume you have the planter bed laid out? in Plan use Terrain feature tool, draw a Spline retaining wall. Open the DBX set the height, change the material to something close to what you want to achieve. See if that works for you or at least gets you close.
You may be misunderstanding me?
I'm looking for the "material" River rocks Folder.
That you showed me in your Pict.
I need a wide selection of "River Rocks" (Material)
I know how to create the beds.
The folder with the surface materials (River / Rocks)
You see that you have a folder with many selections for "River Rocks"
My folder I have 2 selections for river rocks.
Where can I get the folder that you are showing.
Thanks
Thanks
Not sure why your folder doesn't look like mine.  I opened X10 and did the search for River Rock. One of the folders is the CA X10 folder and it has three basic. Don't know how many more you'll find in CA X10. I looked in my X11 has the same folder. Maybe one of the real CA guru's will jump in and offer advice. Sorry I can't help more. Use the Link Eric (Solver) posted and see if you find what you need.
One of the manufacturer's catalogs I previously downloaded (Boral) has a number of Stone / Pebble look textures under "Expose". If you go to the CA 3D Library and search for boral, down load their catalog then open your library browser, >Manufacturer Catalogs>Expose and take a look at those textures?
14 minutes ago, solver said:
Go here and download catalogs.
I have been there.
I do a search for "River Rock". Nothing!
Do I have to download every catalog?
You would think the search for "River Rock" would pull something?
Could you direct me to the catalog that has that folder "River Rock"
So I don't have to download every catalog?
Thanks
7 minutes ago, jjifmeyer said:
I have been there.
Thanks
See the screen capture
6 hours ago, Evolution said:
Could anyone tell me what catalog (River Rock) Materials is located in?
The included pict is what I'm looking for not what I have.
I have been searching for 2 hrs.
Not sure why you refuse to just tell me the catalog?
I have downloaded 8 already with no luck.
Thanks anyway
2 minutes ago, solver said:
One by one, but it should be obvious which ones to get
Have a look in Coronado Stone>Irregular Shaped Stones>Creek Rock and River Rock.
For those that are not aware, after doing a search and finding some textures, you can locate the textures in the library structure and find out the name of the Catalog by right clicking on a texture and select Show In Browser.
Colorado, Rio Grande and Yakima can be found in the Eldorado Stone>Stone>River Rock.
River Rock-Multi and River Rock-White are in Chief Core Catalogs>Materials>Landscaping and Roadways>Decorative Rock and Gravel.
1 hour ago, jjifmeyer said:
Wish the search in the 3d library was a little better.
The library search could be better but in your situation I think you were misinterpreting the fact that when you search it only searches the libraries currently installed on your system, there is no online search feature that looks at all of the available library catalogs.
