lbuttery Posted June 12, 2015 Share Posted June 12, 2015 It would be easier if CA set it up so us nitwits could get this information without having to learn Ruby. Scott: I agree, basic info should be available to the user without using macros Lew Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 12, 2015 Share Posted June 12, 2015 Lew, You have not been listening. Macros are only one of several methods that have been presented. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 12, 2015 Share Posted June 12, 2015 Here's how I would do it: - turn on the layer called "Layout Box Borders" and set the color to something very visible. - select each layout box on each page. - if you see the "Relink File" button on the edit toolbar, click on it. This will show you the file name that the layout box is linked to. Dermot, Unfortunately that only shows the file name, not the full path and file name - which could be a critical item. Of course you can look at the header bar to get the path. BTW, it is not required to display the border of the Layout box. Link to comment Share on other sites More sharing options...
lbuttery Posted June 12, 2015 Share Posted June 12, 2015 Joe: I know and they all need improvement CA's solution should not require macros Lew Link to comment Share on other sites More sharing options...
glennw Posted June 12, 2015 Share Posted June 12, 2015 And he does it again. Thanks Glenn. No problems Scott, but I did suggest that solution way back in post #19, which you must have missed. Seems like a no brainer to me! Too simple for a vid. Link to comment Share on other sites More sharing options...
dshall Posted June 12, 2015 Share Posted June 12, 2015 No problems Scott, but I did suggest that solution way back in post #19, which you must have missed. Seems like a no brainer to me! Too simple for a vid. Sorry about that , sometimes I am a bit dense. Link to comment Share on other sites More sharing options...
HumbleChief Posted June 13, 2015 Share Posted June 13, 2015 Very helpful thread. I constantly have various views sent from various plans as the model evolves and using %referenced_filename% with Layout Labels turned on during Layout creation, then turning off Layout Labels for final printing will help identify any straggler views sent from the wrong plan file. I don't think I need the full path at this time because my plan files are never that far apart in my folder structure. Again thanks for the lively discussion and some great solutions. Link to comment Share on other sites More sharing options...
builtright3 Posted June 13, 2015 Share Posted June 13, 2015 I had to give you a red mark for this Joey. The box you are talking about does tell us what files are associated with this, but it does not help us locate the particular layout boxes that are associated with a particular file. You guys all realize that I am putting my foot in my mouth because in about 43.67 minutes Glenn Woodward is going to come on and give us the answer and I am going to feel like a big nimrod. Thanks Scott I will take the red mark, green mark, yellow mark..... as long as I get some sort of attention here so I don't feel left out. As for this discussion for some reason I don't have any problems with linking and un-linking and cleaning up the files to make template out of them. My problem is I can't really tell you how I do it I just do it. I seem to make thinks work some how. Everyone on the forum has helped me so much that I am very pleased with my new automatic & live plan setup. Very efficient! Maybe I will have to do a video on it soon and share what I have learned with the rest of the world. Its still a drop in the bucket of what can be done with CA but its much better. You brainy-acks are still way over my head. Link to comment Share on other sites More sharing options...
dshall Posted June 13, 2015 Share Posted June 13, 2015 Here is a vid showing the two methods of finding a particular plan file in layout. http://youtu.be/XkXgR3HmFqE Link to comment Share on other sites More sharing options...
HumbleChief Posted June 13, 2015 Share Posted June 13, 2015 Another method if you simply want to get rid of the stray plan references. Link to comment Share on other sites More sharing options...
