Hi.  I am new to CA and am trying to see all of my roof planes in the same view, both for editing and for layout.  The house I'm working on is basically a ranch style home with a steep pitch roof that has been dormered to a create second floor.  I drew the roof planes manually; first, the gable roofs on the first floor, and second, the dormer and shed roofs on the second floor.  Now, I would like to display them all in the same drawing for my layout sheets.  Any suggestions?  Did I draw my roof planes incorrectly?
Thanks in advance,
Pam
Without being able to see your plan file or layout file, no one can but guess what you should do other than read your users guide and Reference Manual. Posting a copy of your plan and layout file and some screen captures of what you are seeing versus what you want to see would go a long way towards anyone helping you.
Welcome to the forum in any case.
If I understand your question correctly....You can move all the roof planes to the same floor level, or you can also do an orthographic view from the top of your project to show an ariel view of all the roof planes.
DJP,  I have attached the two screen shots of the roof planes that I would like to show in one view.
I have watched hours of tutorials on roofs and searched the blog and forum, but haven't come across what I'm looking for yet.
I guess my question is, can I display information from two different floors in the layout?
Or, you could probably use the "Display On Floor Above" tool.
3 hours ago, solver said:
Ditto........
and if you want to read threads and watch videos that will explain what you want ..........do a search of the MRLS
You can use the Display Above or Below Tool on any Roof plane to force the display of all roof planes on Floor 2 on to floor 1 (or vica versa) , it doesn't shift the planes only their display to make them easier to work with.
there is a bit more info in the Ref. Manual on page 791 ...but not much... but it shows what the Tool Icons look like which should appear on the edit toolbar when a Roof Plane is selected.
5 minutes ago, johnstonpm said:
Yes!  Perfect!  Thank you!
Your Welcome :)
Also, it's good to have your Forum Signature filled in, especially with the Software Version, and of course a real Name is nice too :) ..............
See mine below in Blue for how to do that.
If you don't see my Signature then you have them turned off for the Forum so you need to Toggle it on by going to the Upper RH Corner of this Forum Window and Clicking on your Username and making sure Signature are enabled (green) and then Add your Own Sig. too :
UserName> Account > Signatures
Learn to use reference sets for that.
    29115
    JasonS92
    JasonS92
  • Similar Content
    • By woodcraftdesign
      using live camera views in layout, how do I change the size of these in the layout sheet.  I would like my renderings to measure 12" wide but I cannot change the size. Probly just an oversight on my part.
    • By kylejmarsh
      How can I speed up layout? Seems ridiculous that moving some text WITHIN LAYOUT and not even touching my synced viewports has such an awful lag time. I have a fast computer and the modeling is plenty smooth. I also have used lots of other cad software and even old, clunky dried-up CAD software doesn't have the terrible lag that working in Layout has.
      I've devised ways around it - trying to do everything in my model and nothing or as little as possible in Layout - but this is just bad and seems unnecessary. What is going on within the code when moving text like this takes a few seconds?
      Is this common or am I an outlier? I've posted a video of the lag time here - can anybody else corroborate this lag? Is it time for a (nother) computer upgrade, or will even DeepBlue have a similar lag time? Is it some secret setting within chief that is slowing me down like this?
      Screen Recording 2021-03-01 at 3.31.31 PM.mov Screen Recording 2021-03-01 at 3.23.19 PM.mov
    • By intendo
      The red arrows point to the problem area.
      The outside wall and interior wall at the closet intersect with the valley where the two roof planes intersect.
      The interior of the room creates an attic wall (with exterior siding) above the closet (NOTE: Ceiling was removed to get image)
      The plan view shows where the roof planes intersect at the valley. I have the same problem on the other side of the house because it is symmetrical.
      The plan is too large (65MB) but here is the model (https://3d-viewer.chiefarchitect.com/go?share=543146417714334).
      Any suggestion on how to fix this would be greatly appreciated.
    • By ChiefWhataChuck
      Civil engineer asked for roof plan. Currently. I have been able to display roof plains by floor level with slope markers. However, being it is a two level home...how do I display a complete roof for a layout plan? Along with dimensions for roof rain displacement calculation?
    • By DGail1
      At one time, the hinge/swing direction of cabinet doors was displayed in elevation views, but it isn't happening any more.  Is there a setting that I need to change?
