lumber Posted June 14, 2018 Share Posted June 14, 2018 Does anyone know of a way to password protect a drawing so another chief arch user can view the drawing but not make any changes to the drawing? Thanks. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 14, 2018 Share Posted June 14, 2018 send it as a "PDF" Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 14, 2018 Share Posted June 14, 2018 Dropbox, Shared, View Only works for me. 1 Link to comment Share on other sites More sharing options...
lumber Posted June 14, 2018 Author Share Posted June 14, 2018 Yes that will work, but what if they want to do walk thru's Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 14, 2018 Share Posted June 14, 2018 2 minutes ago, Joe_Carrick said: Dropbox, Shared, View Only works for me. Thanks Joe , I had no idea Dropbox had that option., i'll check it out. Link to comment Share on other sites More sharing options...
Chopsaw Posted June 14, 2018 Share Posted June 14, 2018 12 minutes ago, lumber said: Yes that will work, but what if they want to do walk thru's All depends on your level of trust and how much effort you want to put in to protect what is yours. You can always prerecord the walkthrough and send video or give them a link to the model with the 3D Viewer. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 14, 2018 Share Posted June 14, 2018 9 minutes ago, lumber said: Yes that will work, but what if they want to do walk thru's I don't think there's any problem with them opening the plan and using any of chief's features. They can probably even save to a new file - but they couldn't save to the Dropbox location. Link to comment Share on other sites More sharing options...
Chopsaw Posted June 21, 2018 Share Posted June 21, 2018 Not sure but this may possibly address your concerns. "File Locking - Choose whether or not to lock .plan and .layout files when they are open. File Locking prevents another program or copy of Chief Architect software from opening and modifying the same file at the same time and is recommended in nearly all circumstances." Link to comment Share on other sites More sharing options...
Richard_Morrison Posted June 21, 2018 Share Posted June 21, 2018 On 6/14/2018 at 11:59 AM, lumber said: Yes that will work, but what if they want to do walk thru's The 3D viewer software will let them do a walkthrough, but has no editable information. Link to comment Share on other sites More sharing options...
lbuttery Posted June 21, 2018 Share Posted June 21, 2018 Chopsaw: I don't think file locking works that way you have to close the file(s) to send them and that terminates the file locking Lew Link to comment Share on other sites More sharing options...
Chopsaw Posted June 21, 2018 Share Posted June 21, 2018 12 minutes ago, lbuttery said: I don't think file locking works that way I will have to give it a try Lew as I have never uses it but I think I have downloaded forum files of other users that will not allow you to save. Thought that may have been the setting. Link to comment Share on other sites More sharing options...
Smn842 Posted June 21, 2018 Share Posted June 21, 2018 4 hours ago, Chopsaw said: I will have to give it a try Lew as I have never uses it but I think I have downloaded forum files of other users that will not allow you to save. Thought that may have been the setting. Lew is correct. That setting is for holding a lock on the plan file while it is open in Chief which prevents other copies of Chief or other applications from modifying/deleting it. This is the norm for most applications, but I expect the option is there for any rare support issues that arise from holding a file handle on the plan file (possibly some remote file services, poor network connections etc). Even if an application crashes and so skips its normal file closing sequence the operating system will remove such files handles/locks. Link to comment Share on other sites More sharing options...
VisualDandD Posted June 21, 2018 Share Posted June 21, 2018 If you want them to do a walk-through, just export entire house as a symbol. Link to comment Share on other sites More sharing options...
