3D Views/Elevations do not look correct
Member Statistics
Similar Content
By Tlcurtis2a
I've drawn the floorplan for the 7700 SF clubhouse of a development we are building. I need someone to actually do the finishes for the 3D and renderings. I also need someone to finish the terrain work and exterior areas including portico with circular driveway and parking areas, pickleball courts, pool, outdoor seating and firepits. Thank you! Please let me know if you are interested in taking this project and need price for your work.
By Elopez
Hello, I'm new to chief architect and I'm trying to use this sink that I wants in my model but is not in the library so I have to download it from the website. But when I do it comes out in 2D and the 3D one doesn't come out like I want. I have downloaded the sink in drawing DWG, OBJ and I don't know what to do. The pictures at the bottom are the sink and what I get when downloaded. sink
DWG
OBJ
By Danielle_AZL
Hello,
I have come across a lot of matterport ads, but it does not seem to work well with CA without a lot of converting of files. What do other CA users use that is an alternative to matterport?
By basilbabaa
SITUATION: X13 3D renders, when compared to X12, appear blurred, washed out, less vibrant in quality and the vector renders have excessive line weights in X13
Rather than hijack a previous topic thread, I am starting this topic as a result of a side conversation that emerged here-in:
It appears that there are others experiencing this same issue, and so I thought I would begin this here in it's own topic thread.
Here is a Dropbox link to image and video files (generated on both a i9 and M1 Pro Max chips) depicting the issue: https://www.dropbox.com/sh/9zt4tagbuhsfkbi/AABsTnIW6DjT5uExeP6e5mcAa?dl=0
As a note, I have already opened a support case with Chief Technical Support and they have graciously offered to look into it:
If anyone else is noticing lesser quality output with 3D rendering in X13 as compared to X12, perhaps we can share our experience and thoughts here as well as with support towards a workable solution.
By TimelessJohn
Hi All,
I have a small insignificant detail problem that I wish to resolve and wonder if anyone has a Tip or Trick to fixing the fact that my Steel I Beams show up perfectly in my Posts and Deck patio beams but not in my roof beams.
I have changed all of my defaults to I Beams in my settings to no avail, just curious if this a detail I will have to learn to live with or a glitch in Chief?
Also I would like my I beams to show in the interior walls and imagine in order for this to happen I will need to create a niche and paint it black steel? Correct?
Please see attached image.
Thank you in advance,
John
Steel I Beam Issue.pdf
