ChristopherJones Posted February 10, 2018 Share Posted February 10, 2018 Seeking community help. I am a new user and had created a layout in the trial version of Chief Architect Interiors. I cannot save the plan since that would require a purchase of the interior version, I have purchase the full version of the Premier edition. Is there any way for me to copy paste the layout from trial to full version? I have tried copy/paste and it rejects me. Any help or advice is appreciated. I look forward to being part of the forums. Link to comment Share on other sites More sharing options...
Chopsaw Posted February 10, 2018 Share Posted February 10, 2018 If you got all the way to layout without saving it sounds like you are doing well. Unfortunately I don't believe there is any way to transfer the data other than a screen shot so you will be starting out with a good practice session and opportunity to work on your efficiency. 1 Link to comment Share on other sites More sharing options...
ChristopherJones Posted February 10, 2018 Author Share Posted February 10, 2018 thank you, and true that on the practice Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 10, 2018 Share Posted February 10, 2018 I have done it, but it was a long time ago, and the same chief program . You need to open both versions and copy paste to the new version. The trick is to hold down the control key when opening a second version, but never tried using two different versions. It's might be easy for you. Make sure you are on page zero when copying. You can always copy your layout to the lib. and export to the new Chief also 1 Link to comment Share on other sites More sharing options...
lbuttery Posted February 10, 2018 Share Posted February 10, 2018 On Monday contact CA's tech support they may have some tips or they might even be able to do it for you ??? Lew Link to comment Share on other sites More sharing options...
Chopsaw Posted February 10, 2018 Share Posted February 10, 2018 Trial Version Limitations Printing, Saving, Export, Virtual Tours Lew, Not so sure tech support can help as the trial versions are specifically designed as trial versions so that nothing of value can be produced. Link to comment Share on other sites More sharing options...
lbuttery Posted February 11, 2018 Share Posted February 11, 2018 trial versions are specifically designed as trial versions so that nothing of value can be produced Understood, yet only they may have tools that can do something we can't ? Lew Link to comment Share on other sites More sharing options...
tommy1 Posted February 11, 2018 Share Posted February 11, 2018 Sorry but I don't understand. If he has the Premier version, why not just start an actual plan and layout? I mean by now, surely he has closed the Trial version and lost it all right? Link to comment Share on other sites More sharing options...
Chopsaw Posted February 11, 2018 Share Posted February 11, 2018 1 minute ago, tommy1 said: Sorry but I don't understand. If he has the Premier version, why not just start and actual plan and layout? I mean by now, surely he has closed the Trial version and lost it all right? As long as the computer is powered up and Chief Trial is kept open the plan is still there but I don't believe there is any way to get it out. Likely there was quite a bit of effort and electricity put into the trial version so understandably you would look for a way to save it. Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 11, 2018 Share Posted February 11, 2018 Few to none of us have done as you have done. Call Tech Support on Monday and see if they can advise you. DJP Link to comment Share on other sites More sharing options...
tommy1 Posted February 11, 2018 Share Posted February 11, 2018 It would be interesting to find out if CA would enable him to do this. If so, then it's really not a "Trial Version" and they should but and exception in their Trial Version Limitation note saying that if you purchased the full version, then your plan could be saved. The limitation note says that this version can not be saved or printed. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 11, 2018 Share Posted February 11, 2018 I thought if you bought the Full Version that the Trial that was already installed just became a Full version by Entering the Digital Key and Activating it ,( ie. no need to re-install AFAIK ) but in this case they purchased Premier instead of the Trialed Interiors Version which maybe an issue? M. Link to comment Share on other sites More sharing options...
