rtedesignllc Posted July 20, 2017 Share Posted July 20, 2017 Okay I was having problems with Ray tracing in X-8 my Computer would crash in less than 3 minutes doing a simple ray trace... Literally shutting off my computer......Black screen with the message do you want to start your computer normally... I press enter and start all over... S o I Upgraded to X-9 I am running Windows 7 Pro with an AMD-FX 8350 8 core Processor 4.0G ram 8.00 GB Graphics AMD Radeon R-9 200 series... Still happens ...So what could be my problem? It only happens ray tracing and on a quick setting to boot..I then used a very simple model square room and it still crashes...My thought is to uninstall and then reinstall chief 9 I had upgraded from 8 to try and solve it to no avail... Any thoughts would be appreciated Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted July 20, 2017 Share Posted July 20, 2017 Is it possible that your CPU is overheating. When running a Raytrace it will max out all of your cores. You can monitor your CPU with CUPID CPU-Z to see if the temps are getting too high. You could also reduce the number of cores in CA "Edit/Preferences/Ray trace", maybe drop it to half and see what happens. Link to comment Share on other sites More sharing options...
rtedesignllc Posted July 20, 2017 Author Share Posted July 20, 2017 Thanks I'm ready to try anything in Edit Preferences ray trace what am I looking to change? Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted July 20, 2017 Share Posted July 20, 2017 You want to reduce the number of cores used. It is likely displaying all your available cores, just set to half of them and then run another Trace. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 20, 2017 Share Posted July 20, 2017 I've had this happen in the past. It was an overheating problem just like Graham is suggesting. I opened up my machine and cleaned all the dust out and the problem went away. Ever since then I've made a habit of cleaning my machine out fairly regularly. Link to comment Share on other sites More sharing options...
johnny Posted July 20, 2017 Share Posted July 20, 2017 Graham is giving good advice here, as I had a similar issue and fixed it the way he is saying. My newest system has a GREAT cooling package and I am able to render with all my cores active now - but my last computer not so much. AMD chips run much hotter than Intel - its one of their characteristics. You may want to add a water-cooling system to your chipset. http://www.tomshardware.com/forum/67008-28-cpus-generally-hotter-intel This is what your processor looks like when rendering: Link to comment Share on other sites More sharing options...
rtedesignllc Posted July 20, 2017 Author Share Posted July 20, 2017 Thanks I will try that... Link to comment Share on other sites More sharing options...
glennw Posted July 21, 2017 Share Posted July 21, 2017 I had been having very annoying computer crashing and mainly freezing problems for the last couple of months - they were random and inexplicable.. I just couldn't track down the problem. I tried all the usual things like cleaning, reseating the ram and graphics card etc. I then thought it may be an overheating problem, but all the fans seemed to be working properly and there didn't seem to be any dust problems. I then removed the cpu fan, cleaned off what was left of the thermal paste (it was sparse and patchy) and applied new paste. I did this about a week ago and haven't had a freeze or crash since - the computer is running like a dream. I can only assume the problems were caused by an overheating cpu caused by the old thermal paste. I have since done some googling and there is plenty of anecdotal evidence that thermal paste can dry up and deteriorate, causing problems. Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 21, 2017 Share Posted July 21, 2017 The only time I ever had crashing problems was back in Version 6 in 1999 and it came down to a corrupted mouse driver which I updated solving that problem. If I had such a problem again that is the FIRST action I would take to handle. DJP Link to comment Share on other sites More sharing options...
Dan_Park Posted July 21, 2017 Share Posted July 21, 2017 When the computer shuts down as described it's usually overheating or an overload on the power supply. Systems are designed to shut off due to overheat or low voltage to protect the system components. I agree with the other advice here in that I would suspect overheat more than overload. However, a large power draw by the CPU might put a weak power supply over the edge. Link to comment Share on other sites More sharing options...
