GLOBE-Res Posted May 13, 2017 Share Posted May 13, 2017 My computer suffered a rapid power cycling of 4 times and screwed it up, so, I had to go buy a new computer. So, I have version 9.5, that I guess was for a 32 bit computer. I also have a USB hardware lock. I was fine with that version. It worked, it was paid for, it did what I needed, no muss, no fuss. But, it won't acknowledge the usb hardware lock on the new computer, any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 13, 2017 Share Posted May 13, 2017 You must go and download updated drivers for the dongle for Windows 10 or whatever you have or no go. I dual boot with Windows XP and Windows 10 where I use XP for antique software. DJP 1 Link to comment Share on other sites More sharing options...
GLOBE-Res Posted May 13, 2017 Author Share Posted May 13, 2017 I have no idea how do do that. Ho do i "dual boot"? Where do I go for drivers? Gosh I'd love to get this all running. I miss my old puter Link to comment Share on other sites More sharing options...
lbuttery Posted May 13, 2017 Share Posted May 13, 2017 If you hunt around you can find an old XP computer to run Chief 9.5 on and use the new computer for other activities Lew Link to comment Share on other sites More sharing options...
GLOBE-Res Posted May 14, 2017 Author Share Posted May 14, 2017 Ok so what if my other computer is a 64 bit computer that was running windows 7, if I'm not mistaken, that computer won't load the program because the program is built on a 32 bit os platform. Is there a way to change the software to run on a 64 bit os? Link to comment Share on other sites More sharing options...
GLOBE-Res Posted May 14, 2017 Author Share Posted May 14, 2017 If I buy the X9 outright for $2695 today, what happens 12 months from now? Do I have to buy it again or can I use it as is as long as I want? I bought version 8, then upgraded to version 9.0, then version 9.5. I haven't needed to upgrade since. But, my computer suffered a boot up problem because of a bad storm and I was forced to buy a new computer. The new computer won't run the v9.5 Chief. And to make it worse, the new Chief won't load my 9.5 projects. I'm really ticked off. I have a lot of projects that are now of no use. That's so F'k up. I can't even complete 4 projects started in Chief just in the last few months. So, I'm forced to either buy new Chief software or go to another program. That old 9.5 was just fine for me. I didn't need to upgrade. So, If I buy the X9 this year, am I forced to upgrade or will I be able to get as many years as I want out of it? Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 14, 2017 Share Posted May 14, 2017 20 minutes ago, GLOBE-Res said: If I buy the X9 outright for $2695 today, what happens 12 months from now? Just as you have not upgraded past 9.5 you can stay with X9 for as long as you like, it is a personal decision, there are no absolutes. There is NO good reason to do anything other than to get Chief Premier 9.5 installed and running on your new PC. It does require some persistence by you but others have done this successfully and you can to. There is no reason why you cannot just repair your old computer and then just drive on also. Just decide what you want to have happen and then do what is necessary to make it so. DJP Link to comment Share on other sites More sharing options...
lbuttery Posted May 14, 2017 Share Posted May 14, 2017 Software has no guarantees to run "forever" software is designed for the OS that was available at that time who knows what the future will bring do as David suggests or find an old XP computer and load 9.5 on it Lew Link to comment Share on other sites More sharing options...
BrownTiger Posted May 16, 2017 Share Posted May 16, 2017 In theory you could get a hasp driver from http://www3.safenet-inc.com/support/ and create shortcut and set compatibility mode. But I do not have a slightest clue what 9.5 version is... Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 16, 2017 Share Posted May 16, 2017 8 hours ago, BrownTiger said: In theory you could get a hasp driver from http://www3.safenet-inc.com/support/ and create shortcut and set compatibility mode. Others have reported that they have done as above and also say that Version 9.5 runs fine otherwise (what they mean by "fine" may or may not agree with your definition of "Fine" but that is what several other Chief Users have reported here within the last year or so. AS I have said, I went the dual boot route where 9.5 and other versions created to run in XP actually do run quite well. Windows XP is still the third most used operating system worldwide but I would NEVER use it for internet browsing as it has way too many security weaknesses for that these days. But is fully capable of supporting applications that were designed to run within it. DJP Link to comment Share on other sites More sharing options...
BrownTiger Posted May 18, 2017 Share Posted May 18, 2017 >Windows XP is still the third most used operating system worldwide but I would NEVER use it for internet browsing as it has way too many security weaknesses for that these days. The weaknesses were not just in a browser, but network drivers (SMBv1). If you use file shares XP can only do v1s. But there are also countless security issues. I would not recommend. Link to comment Share on other sites More sharing options...
BobbyS Posted December 12, 2020 Share Posted December 12, 2020 November 2020 This is an old thread but maybe this will help someone. Had a hard drive crash and had to reinstall Chief Ver 10.0 in a fresh install of Windows 10 (latest version 1004 with all current updates through November 2020). Yes Chief Architect Version 10 or 10.08 still works and I would think this works for earlier versions.. After installing version 10.0 from my saved installation files, Windows 10 would not allow me to open the Chief Architect program as the User Account Control (UAC) security stopped the program from opening. I had to go into Registry Edit and turn UAC off (note many online articles as how to do this and turn it on and off). After the install of Chief Architect 10.0, the program could not find the HASP key. Took a while but I found the following to get new hasp key drivers. I suggest deleting all old Hasp Key drivers (mine were Aladin files/drivers) prior to installing the new downloaded files/drivers (which will be Sentinel). Once I got the Hasp Key recognized I updated to 10.08 and Chief 10.08 works as normal.. Go to step 3 for the file to download the drivers. Please uninstall any old drivers first. You may need to insert the hasp key for the files/drivers to show in Control Panel/Device Manager/USB controllers to uninstall them. 1. Went to site: Thales Customer Support Portal at: https://supportportal.gemalto.com/csm/?id=portal_home_page then using their search look for the following: hasp driver chief architect 2. That search will lead to the following page: https://supportportal.gemalto.com/csm/?id=kb_search&q=hasp%20drivers%20chief%20architect where you will look for: Sentinel HASP/LDK Windows GUI Run-Time-Installer 8.13 3. This is the download site for the driver: There no spaces in this address. This thread would not allow word wrap for the long string. https://supportportal.gemalto.com/csm/?sys_kb_id=61fb0ee1dbd2e78cfe0aff3dbf9619ab&id=kb_article_view&sysparm_rank=21&sysparm_tsqueryId=957514cbdb9ce41080b234523996196e The following is the file description needed: Sentinel® LDK and Sentinel HASP® Run-time Environment Installer GUI for Windows Refer to the Readme file included in the package for details. MD5 (Sentinel_LDK_Run-time_setup.zip) = 2b9a4dc20e6acc32cc9e4636b1d5eafa Sentinel HASP/LDK Windows GUI Run-Time-installer 8.13 after being installed and then checking Device Manager under Universal Serial Bus controllers shows: Sentinel USB Key Sentinel HL Key Sentinel USB Key Note that all three show the driver version is actually 7.92.0.0 with a date of 03/29/2019 Hope this helps. Bob Schroeder Sarasota, FL rschroeder@comcast.net Link to comment Share on other sites More sharing options...
Kbird1 Posted December 13, 2020 Share Posted December 13, 2020 On 12/12/2020 at 8:43 AM, BobbyS said: November 2020 This is an old thread but maybe this will help someone. Sentinel HASP/LDK Windows GUI Run-Time-installer 8.13 after being installed and then checking Device Manager under Universal Serial Bus controllers shows: Sentinel USB Key Sentinel HL Key Sentinel USB Key Note that all three show the driver version is actually 7.92.0.0 with a date of 03/29/2019 Hope this helps. Bob Schroeder Sarasota, FL rschroeder@comcast.net Nice Tutorial Bob , I'd suggest you also Put it over in the Tips Forum with some Tags for Hasp and 10.08 as this seems to be asked monthly at least and may get lost on this old thread. https://chieftalk.chiefarchitect.com/forum/24-tips-techniques/ Link to comment Share on other sites More sharing options...
Gawdzira Posted December 14, 2020 Share Posted December 14, 2020 I have a suggestion https://classics.autotrader.com/classic-cars/1983/delorean/dmc_12/101414839 Link to comment Share on other sites More sharing options...
Gawdzira Posted December 30, 2023 Share Posted December 30, 2023 2 minutes ago, Rickster said: Sorry... The Delorean is gone!! It looks like someone got there before you. Or maybe it was after you? 1 Link to comment Share on other sites More sharing options...
KevinWaldron Posted December 30, 2023 Share Posted December 30, 2023 VMware might be your answer. kw Link to comment Share on other sites More sharing options...
mthd97 Posted December 31, 2023 Share Posted December 31, 2023 I recently bought a brand new gaming computer with XP pro installed on it for Archiving purposes. I got it from eBay. I have never seen XP work so fast. I installed CAV9.5 & 10 on it but I had to install the HASP driver manually from the actual dongle. All works good now. I spent $800 AU or approximately $500 USD because I have heaps of plans stored in CAV10 and earlier. To move my legacy plans and layouts to later versions of CA, I open them in X8 and save them, then work on them in that version or later if possible. Not a simple exercise. Link to comment Share on other sites More sharing options...
mthd97 Posted January 3, 2024 Share Posted January 3, 2024 5 hours ago, Rickster said: Hey mth97, Couldn't you just plot a PDF of the layouts for filing those projects and leave the CAD files where they are until you really need them? I have setup a New Layout file for the newer Chief X6. I then copy the .PL* plans to an X6 file folder THEN import them. The existence of an X6 folder in the project folder indicates their maybe something for this project elsewhere. I copy them as Chief has a nasty habit of cutting those PL* files and place them elsewhere. Then all you have to is resend those prints to your newer layout. once you've place them into their new file folders. Hi, If you are ok with just 2D plan files as either PDF or DWG, sure you can do something like that. I have recently taken a very complex split level home including the terrain from V9.5 and saved it in X8 along with the old layout file and they both look fine. I can also open the plan in X10 to work on it and it all looks right. The layouts I can only work in X8 for now but that’s cool, I am ok with working in X8 or doing new layouts in X10 after a re-modeling. It even works fine in going from windows to Mac as I did above. Well done to CA for making it relatively straight forward. Link to comment Share on other sites More sharing options...
mthd97 Posted January 3, 2024 Share Posted January 3, 2024 Hi Rickster, I asked in a question thread about a year ago and got a reply directly from Chief Architect staff saying to use that particular method. Please see this article for details on why. https://www.chiefarchitect.com/support/article/KB-00279/opening-legacy-files.html No problems ! Link to comment Share on other sites More sharing options...
