Mrducks Posted April 27, 2017 Share Posted April 27, 2017 I am VERY new to this program, and until a few weeks ago I was pushing a pencil around my drawing board. I was watching the instructional video on creating a CAD block of the as-built drawings to be used as an overlay/mask on my plan view so I could move walls and see where the original walls were. In creating the block, I think I did everything correct, but I accidentally clicked on exploded view of the block. it did not seem to do anything, however when I move the block to my drawing, a few parts and pieces of the drawing are missing. is there a way to undo this error? or, should I start over? Thank you! Steven Link to comment Share on other sites More sharing options...
javatom Posted April 27, 2017 Share Posted April 27, 2017 You could check archives and see if that saved version still has it as one intact block. Link to comment Share on other sites More sharing options...
Mrducks Posted April 27, 2017 Author Share Posted April 27, 2017 Thank you for that help. it worked. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 27, 2017 Share Posted April 27, 2017 Put that cad block, and unblocked lines, on a separate layer so you know where they are, and lock it if you find yourself losing lines. 1 Link to comment Share on other sites More sharing options...
glennw Posted April 28, 2017 Share Posted April 28, 2017 On 4/27/2017 at 4:13 PM, Mrducks said: is there a way to undo this error? or, should I start over? Expand That's what Undo is for. Link to comment Share on other sites More sharing options...
Chopsaw Posted April 28, 2017 Share Posted April 28, 2017 Cad Block Management could also be used to bail you out of a situation like that if it is too late to undo. Link to comment Share on other sites More sharing options...
DianneDSC Posted April 28, 2017 Share Posted April 28, 2017 I create a cad detail from view and then create the cad block in the cad detail window. This way the original line work is available if needed to adjust anything or reblock. Also, I do a save-as of my plan and name it "whatever"as-built.plan so I have the 3d version available as well. Then open up the working plan to start on the proposed remodel. Link to comment Share on other sites More sharing options...
dshall Posted April 28, 2017 Share Posted April 28, 2017 On 4/27/2017 at 11:26 PM, DRAWZILLA said: Put that cad block, and unblocked lines, on a separate layer so you know where they are, and lock it if you find yourself losing lines. Expand On a separate later, yes. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 28, 2017 Share Posted April 28, 2017 I like to lock it for safety and highly recommend it, you can lock the layer or the cad block. Link to comment Share on other sites More sharing options...
ACADuser Posted April 28, 2017 Share Posted April 28, 2017 Locking on the demo layer also has the benefit of not snapping to those lines. Link to comment Share on other sites More sharing options...
