MarkSM Posted April 22, 2017 Share Posted April 22, 2017 I have this wall in plan view, but it's not showing up on any of my elevation views. I've tried everything I can think of, including deleting and redrawing everything, no luck. I'm sure there's an easy answer, but I can't find it for the life of me. (X9) Link to comment Share on other sites More sharing options...
lbuttery Posted April 22, 2017 Share Posted April 22, 2017 Mark: you will need to post the plan otherwise, its only guesses Lew Link to comment Share on other sites More sharing options...
chief58 Posted April 22, 2017 Share Posted April 22, 2017 Like Lew said just guessing but is your roof covering those walls that is what the picture looks like Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 22, 2017 Share Posted April 22, 2017 I can see that the lower roof plane is in the way so the walls can't generate. Just move the roof plane back. Link to comment Share on other sites More sharing options...
ShaneK Posted April 22, 2017 Share Posted April 22, 2017 Do as the Perry suggests Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 23, 2017 Share Posted April 23, 2017 21 hours ago, MarkSM said: I'm sure there's an easy answer, The basic programming of walls and roof planes is that roof planes cut off walls at the plane of the roof. Perry and Shane pointed this out, the roof plane is cutting off the walls you can see in plan view and is causing what you are seeing in camera views. It is the way Chief Architect Premier and Home Designer is programmed to work, so you work with it, following its programming rules. DJP Link to comment Share on other sites More sharing options...
MarkSM Posted April 23, 2017 Author Share Posted April 23, 2017 Thanks for the input guys. I sort of fixed the stairs (although there is still something not right) and now I've somehow created the same problem with the wall on the balcony. The floor plan shows a railing, but the elevation shows a wall. Balli2.plan.zip Balli2.plan.zip Link to comment Share on other sites More sharing options...
justmejerry Posted April 23, 2017 Share Posted April 23, 2017 Take the two walls and centre them on the one that already shows and they will show up as railings. Link to comment Share on other sites More sharing options...
MarkSM Posted April 24, 2017 Author Share Posted April 24, 2017 17 hours ago, justmejerry said: Take the two walls and centre them on the one that already shows and they will show up as railings. Thanks for the reply, Jerry. What 2 walls and which one that "already shows up"? Link to comment Share on other sites More sharing options...
justmejerry Posted April 24, 2017 Share Posted April 24, 2017 Your two railing walls that don't show as railings. Centre them on the railing wall that does show properly. Link to comment Share on other sites More sharing options...
