How To Drop a Single Room's Ceiling Height Two Story Building
HumbleChief
  On 1/7/2017 at 6:23 PM, dshall said:
Via the ceiling finish option.  Note that the ceiling finish can be any thickness you want it to be.Screen Shot 2017-01-07 at 10.22.31 AM.png
Expand
But that won't frame ,I would use a ceiling plane and add your own ceiling height or create a floor structure from above with the dropped ceiling included in the structure. X9 fixes that
Expand
That is not so.  It will frame auto.....  however I will admit it is difficult to control the direction of the dropped ceiling joists.
See  picture,  the orange ceiling joists is part of the CEILING FINISH and has framed auto.  The ceiling joists of the roof has also framed auto.  I did no manual framing,  what you see is all auto.  The orange joists represent a dropped soffit in the hallway.
I like to do it the way Scott does it. This way frames properly and doesn't alter any walls it attaches to. With a ceiling plane your wall plates on adjoining walls will drop to accommodate ceiling. Ceiling plane you do not get framing for ridge and sub fascia so only what would be dropped joists frames. Ceiling finish gives you framing all around, albeit doubled.
I should correct the above slightly. as long as you have ceiling plane only to drywall finish it won't affect framing of adjoining walls. However you would have more manual touch-up to place dropped joist where they need to be, If ceiling would be framed before drywall.
And just to repeat, if you want to change the ceiling structure of a first floor room you cannot do so by changing the ceiling structure of that room. Really? Yes really. You need to change the ceiling 'finish', add a ceiling plane, or add structure to the floor above.
Just to be clearer the ceiling structure dbx of a first floor room has no bearing or effect on that room's ceiling structure. Sigh...
  On 1/7/2017 at 7:51 PM, HumbleChief said:
And just to repeat, if you want to change the ceiling structure of a first floor room you cannot do so by changing the ceiling structure of that room. Really? Yes really. You need to change the ceiling 'surface', add a ceiling plane, or add structure to the floor above.
Expand
actually to be clearer,  you might want to change the ceiling finish,  I am not sure if you can change the ceiling surface.
  On 1/7/2017 at 7:53 PM, HumbleChief said:
I created a floor above that room and defined that floor to have an added framing layer, then lowered the ceiling. Video shows it if you can make it through.
Expand
Well,  I am not sure if that is what I am doing or what Perry is doing or what Jerry is doing or what Jon is doing.  I think we are all adding the framing to the ceiling finish and not to the ceiling structure and not to the floor assembly.  I do not think anybody is creating a floor above the room....  there is already a floor at the second floor.
