mtldesigns Posted December 26, 2016 Share Posted December 26, 2016 I know there must be a setting based on room type, but having no luck finding it, and its probably right in front of my face. My bathrooms, and other "wet" rooms have no issue of a GFI coming in automatically. My last three plans have had this issue, so I either messed with something in the defaults or who knows? Right now, my work around is copy paste from bathroom, but that's not how it should be. Thanks for any help in advance. Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 26, 2016 Share Posted December 26, 2016 If your room is named "Kitchen" or "Bathroom" any outlets should, when placed come in as "GFI". What did you name the "Kitchen" in question? DJP Link to comment Share on other sites More sharing options...
Chopsaw Posted December 26, 2016 Share Posted December 26, 2016 David, This seems to be more complicated as my "Auto Place Outlets" do not place in the Bathroom at all and even manually placed outlets in the Kitchen are not GFCI. Link to comment Share on other sites More sharing options...
joey_martin Posted December 26, 2016 Share Posted December 26, 2016 I am unaware that GCFI outlets were ever placed automatically in Kitchens. To make sure I wasn't loosing my mind, I just opened the help file and it does not say anything about kitchens, only BATH or MASTER BATH. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted December 26, 2016 Share Posted December 26, 2016 Also check your Electrical defaults and see what you have as defaults. Link to comment Share on other sites More sharing options...
joey_martin Posted December 26, 2016 Share Posted December 26, 2016 1 minute ago, Chopsaw said: David, This seems to be more complicated as my "Auto Place Outlets" do not place in the Bathroom at all and even manually placed outlets in the Kitchen are not GFCI. In baths, there will only be ONE auto outlet placed. If you have a vanity placed first, it will place it at the vanity. Link to comment Share on other sites More sharing options...
Chopsaw Posted December 26, 2016 Share Posted December 26, 2016 Thank You Joey, Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 26, 2016 Share Posted December 26, 2016 1 hour ago, mtldesigns said: I know there must be a setting based on room type, but having no luck finding it, and its probably right in front of my face. My bathrooms, and other "wet" rooms have no issue of a GFI coming in automatically. My last three plans have had this issue, so I either messed with something in the defaults or who knows? Right now, my work around is copy paste from bathroom, but that's not how it should be. Thanks for any help in advance. If you're manually placing outlets, you can temporarily change the kitchen room type to a Bath. Once you're done, simply change the room type back to Kitchen. If you're trying to auto place outlets, I think the best you'll probably be able to do is to first auto place outlets, then: group select the outlets you wish to change to a GFCI open the SYMBOL specification DBX>Options and check GFCI click on the 2D Block tab and select the GFCI block You can also pull GFCI outlets directly from the library. EDIT: I don't normally use Auto Place Outlets, but after Chopsaw mentioned something from the Help files below, I tested it out and Auto Place Outlets should automatically place GFCI outlets over all kitchen countertops. Works for me anyway. Link to comment Share on other sites More sharing options...
Chopsaw Posted December 26, 2016 Share Posted December 26, 2016 18 minutes ago, joey_martin said: I just opened the help file and it does not say anything about kitchens, only BATH or MASTER BATH. Joey, It is included in the help file but still does not seem to work. "For example, GFCI (Ground Fault Circuit Interrupter) outlets are placed over cabinets in Kitchen, Bath and Master Bath rooms." So as I see we are faced once again with using workarounds. Hoping that Chief gets this right in the next version. But until then thank you for the workarounds Michael. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 26, 2016 Share Posted December 26, 2016 Auto Place outlets WILL auto place GFCI over kitchen countertops for me. Thanks for pointing that out Chop. Link to comment Share on other sites More sharing options...
joey_martin Posted December 26, 2016 Share Posted December 26, 2016 Yep. Mine does too. Never used that feature. Still learning I guess. Link to comment Share on other sites More sharing options...
Chopsaw Posted December 26, 2016 Share Posted December 26, 2016 Ok I got it, It just did not like my shortcut with quickie trial plan. It will place outlets over the cabinets and they are GFCI just not over the sink cabinet. Thanks Guys. Link to comment Share on other sites More sharing options...
