Baseboard showing up on exterior elevations
cjanderson66
I am working on a very complex remodel with several different levels on it and I am having trouble setting floor levels.  In one situation, I may have changed and exterior wall height and now my interior baseboards are showing on my exterior elevations. What you are looking at is an upper level floor with a garage below and the baseboards/flooring are showing in the upper floor on the exterior elevations.  For the life of me I cannot firgure it out and I know that there is a CA expert here that can help.
Thanks,
On 11/30/2016 at 4:12 PM, Kiwideziner said:
I have basically fixed it, as I had to go to an exterior elevation and adjust the walls on the upper and lower floor.  I am still a bit confused sometimes as to floor levels and adjusting the walls/foundation in elevation mode.  As with anything there is always a learning curve.
On 12/9/2016 at 3:34 PM, Griffin said:
