mslewis620 Posted September 18, 2016 Share Posted September 18, 2016 Working on a plan and I keep running into a problem in one room of the plan. Every time I draw a wall in this area it splits the wall into two sections no matter what I do. If I click in the space this invisible wall shows up but I don't know how to get rid of it. It also divided the "room" into distinctly labeled spaces. Never encountered this - any suggestions would be appreciated! Martha Link to comment Share on other sites More sharing options...
glennw Posted September 18, 2016 Share Posted September 18, 2016 Without seeing the plan, I am guessing it is the Connect Island Rooms setting in the General Wall Defaults. Link to comment Share on other sites More sharing options...
mslewis620 Posted September 18, 2016 Author Share Posted September 18, 2016 Thought I attached a screen shot - I looked at the setting and it was checked but didn't solve my problem. So odd. Now I don't see a way to attach the file. Link to comment Share on other sites More sharing options...
ShaneK Posted September 18, 2016 Share Posted September 18, 2016 Use "reply to this topic" button at top of page. When dbx opens you will notice an "Attach" button. You must post plan if you want a diagnosis. Plan must be CLOSED and "zip it" if too large Link to comment Share on other sites More sharing options...
builtright3 Posted September 18, 2016 Share Posted September 18, 2016 I had that problem before and I turned on "Show all layer sets" and found that their was a type of wall in there that I had turned off that was causing the break. Link to comment Share on other sites More sharing options...
rlackore Posted September 19, 2016 Share Posted September 19, 2016 Thought I attached a screen shot - I looked at the setting and it was checked but didn't solve my problem. So odd. Now I don't see a way to attach the file. I think Glen's point was that it may want to be UNchecked. Link to comment Share on other sites More sharing options...
Dermot Posted September 19, 2016 Share Posted September 19, 2016 You should not turn off the option to automatically connect island rooms. An "island" room is created when you have an interior room that is not connected to any exterior walls. If they are not connected, you will very likely have problems with things like room definitions, floors, ceilings, moldings, and more. If you don't like where the program puts the automatic room dividers, then you can manually draw your own. Once you have drawn your own, you can then delete the automatic one and it should not come back. If you don't want to see the room dividers, then just turn off the layer. As always, if you have any problems with this, I would recommend you contact technical support for more help. Link to comment Share on other sites More sharing options...
Gawdzira Posted September 19, 2016 Share Posted September 19, 2016 The most mysterious thing about this post is why you did not post the plan? Link to comment Share on other sites More sharing options...
rlackore Posted September 19, 2016 Share Posted September 19, 2016 You should not turn off the option to automatically connect island rooms. Then why is there even an option to turn it off? Link to comment Share on other sites More sharing options...
Dermot Posted September 19, 2016 Share Posted September 19, 2016 Then why is there even an option to turn it off? Because all automatic behavior should have an off switch. 1 Link to comment Share on other sites More sharing options...
mslewis620 Posted September 21, 2016 Author Share Posted September 21, 2016 Got distracted with inspections and forgot to check back in. I've finally attached the screenshot of what's going on. Link to comment Share on other sites More sharing options...
ShaneK Posted September 21, 2016 Share Posted September 21, 2016 Post the plan Link to comment Share on other sites More sharing options...
Gawdzira Posted September 21, 2016 Share Posted September 21, 2016 Without a doubt I can say with complete confidence that the reason that wall is there is because you did not post the plan. Link to comment Share on other sites More sharing options...
