WhistlerBuilder
Speeding up performance with large designs (hardware question)
Hi Everyone,
I was just wondering what people did to boost the performance speed of the software when working with larger drawings. I have recently been working on some 45-100+ unit apartment buildings with chief and I have noticed that even though I have a pretty good computer many actions start to trigger significant delays or glitchy freezes once the plans get large and complicated enough.
The system I am running is:
Operating System
            Windows 7 Professional 64-bit SP1
        CPU
            Intel Core i7 3770 @ 3.40GHz    43 °C
            Ivy Bridge 22nm Technology
        RAM
            32.0GB Dual-Channel DDR3 @ 668MHz (9-9-9-24)
        Motherboard
            ASUSTeK COMPUTER INC. P8Z77-V PRO/THUNDERBOLT (LGA1155)    37 °C
        Graphics
            27MP35 (1920x1080@59Hz)
            L1953T (1280x1024@60Hz)
            2048MB ATI AMD Radeon R7 200 Series (MSI)    47 °C
I think upgrading to windows 10 will help the overall utilization of the ram I have. But I am worried that the freezing and glitching I am experiencing is caused by not having enough graphic processing power as chief tends to calculate the 3D elements of a plan even when not in 3D viewing.
Some advice from any techies or people doing large drawings would be very much appreciated.
Cheers,
Chief has a major problem with large models, there's no denying it. Check the system in my signature. It's pretty muscular but I still get bad slow downs when the models get large. I'm not sure where the bottle neck is, either graphics card or CPU but you'll need LOTS of muscle if you want to try and get through Chief's large models without slowdowns. I'm not talking bothersome slow downs, I'm talking crippling slowdowns that you have to wade through once a model gets so large.
If you want a fast computer here's a link I just posted to the Chatroom that has about as much budget muscle that can be reasonably afforded.
https://chieftalk.chiefarchitect.com/index.php?/topic/10545-need-a-fast-inexpensive-computer/
Thank you for the link. The build you are suggesting has increased processor cores and Ram. You think the chugging / glitchy performance issues are due to core usage / ram usage and not video card processing power?
I'm not sure how one could tell for sure but the newer NVidia cards aren't that expensive for a LOT of graphics power. Will that fix it? Again no way to really tell until the money is spent and the computer put through its paces.
I really don't think that anything can help with a 45-100 unit apartment building. The only thing might be to draw each model separately and use a symbol for the whole building. I believe Chief just wasn't designed for very large commercial projects.
I can't believe I'm actually agreeing with Perry, but I think there are projects that are really too large for Chief and you are probably there.
This was discussed in another thread where a unit plan was copied multiple times, resulting in several hundred walls, doors, cabinets, appliances, etc.  To avoid this problem, create the single unit plans (however many different units required) but then just show the separation walls for each unit and label the unit types where they occur.  The unit plans can even be in separate Plan Files if you want.
It's not really the size of the project that matters but the number of surfaces (walls generally have lots of surfaces since they are made up of layers)
IOW, minimize the number of interior walls, doors, etc.  This is the way we would have done it on paper before we had CAD systems.
BTW, this problem is most evident in the Plan View performance - not so much in 3D if you have a good graphics card with sufficient memory.  Evidently the 2D Display is  being handled by the CPU - not by the GPU.
While there are workarounds, such as Joe's, to speed up the issues related to large numbers of faces, this defeats the whole purpose of BIM. With a stripped down model, you can't get accurate material takeoffs, dynamic door & window schedules that are accurate, etc. There is something to be said for using the right tool for the job. Chief is a great program, but it isn't designed with 100-unit apartment buildings in mind.
Mmm hmmm. I know that's right...snap snap.
Absolutely agree. Need to use the right tool for the job. I can rip a 12" beam in half nicely with my table saw but I have to remove the guard, cut it once, flip it over, cut it again, finish cutting the last bit with a handsaw or reciprocating saw, then touch up the cuts as necessary with a planer or belt sander. It's slow, tedious, difficult, somewhat dangerous and leaves a bit to be desired. If I want to do that more than once it's probably time to set up a bandsaw mill, chainsaw mill, or some other tool BUILT FOR THE JOB. In this case...I'd be looking at Archicad.
Hmmm...I had no idea Archicad could cut a 12" beam... :D
AWW MAN!!! I had a feeling that was coming :)
I experienced the slow down with a STORAGE BUILDING   (many 10'x10' rooms).  It was not a difficult model.
I agree with Richard,  a stripped down model plays havoc with BIM.  Somehow,  CA must fix this......  instancing?  Maybe?
It's just my opinion but I think instancing only works with 3D (GPU handles instances) but that's only Perspectives and Isometric Views.  The Plan Views and Sections/Elevations are really 2D representations of the Model (that's why we can add Text, Dimensions, & other 2D CAD objects to those views) and I think are displayed by the CPU by redrawing them.
Maybe those views could somehow be displayed via the GPU using instancing but I don't think so.
I think a better solution would be for CA to implement either:
  1.  A viewport save and restore (with x/y offsets) when panning or zooming.
  2.  Offset the viewport itself when panning.
  3.  Change the scale factor of the viewport when zooming.
Either of those should be much faster than a redraw of the 2D representation of the model.
I have done what Perry has suggested. I will even go as far as putting elevations and details in a separate plan file. Copy and paste in place is your friend when it comes to multifamily.
ArchiCAD has an interesting approach. They use technology called "predictive processing," maybe named just to get a patent on it. You can have a bunch of views with tabs. When you make a change in one tab, the updating to the other views goes on the background, so that when you open another tab, the change is already done and the update seems instantaneous. That said, I recreated Scott's storage building (and then some) in ArchiCAD just to see how it would behave compared to Chief. 2D panning was instantaneous, and I don't think any 3D views, including sections and elevations, took more than a second to two to rebuild. They've figured out how to deal with large models.
Years ago (1980's) at CalComp Systems Division we had a "Picture Processor" which was essentially a 2D GPU.  This was one of the first (or maybe the first) hardware solution to the problem.  Actually, current GPU's perform the same functionality.  The problem with Chief is that the 2D view is a software representation of the 3D Model.  The 2D View graphics doesn't actually exist as a database that can be processed by the GPU - instead, it's created on the fly which can only be done by the CPU.
It would be interesting to see if Scott's model would be much faster if "Walls, Main Layer Only" was checked.
Thank you for the insights everyone. In agree that it seems chief is not the software to use for such a building. This is unfortunate as I am finally getting trained up and efficient in it. The symbol suggestion was something I was considering, but the main reason I drew this up in chief was to try and make use of the material estimating feature.
I will see what I can do in regards to updating OS and graphics card, but I don't expect that much of an improvement.
    27489
    ChiefRochelle
    ChiefRochelle
  • Similar Content
    • By PvdPol
      Dear all,
      I'm new to the forums and i've tried to find my way in the already existing topics, such as
      - https://www.chiefarchitect.com/products/sysreq.html
      - https://chieftalk.chiefarchitect.com/topic/21934-hardware-recommendations/?tab=comments#comment-179153
      I could not find an answer yet, hopefully some of you can help me out.
      I am currently struggling with Chief Architect Premier, ray traces are really slow at 1080P (1 pass takes like 15-30 min)
      Also working for in PBR is making my system really really slow and it is getting frustrating.
      My model is not complex and I think I need an hardware upgrade.
      Current machine (Notebook - April 2014)
      X•BOOK 15CL56 NVIDIA GTX770m 3GB, Full HD (+/- 20000 3DMARK) Intel® CoreTM i7-4710MQ (6M Cache, up to 3.50 GHz) - 47Watt (Quadcore) 16GB DDR3L (1600MHz)
        New system specifications (not bought yet)
      AMD Ryzen 7 3700X Boxed MSI X470 Gaming Plus Max Crucial Ballistix Sport LT BLS2K16G4D30AESB  (32GB Ram) Intel 660p 1TB Solidstate drive Graphic card? Nvidia? Any Advice?
      I think the 32 GB of memory is already an overkill, not sure if this is needed.
      But I'm mostly wondering regarding the choice of CPU and Graphics card
      Is this a good setup? What kind of performance improvements can I expect? What would be your advice?
      Thank you!
      Regards,
      Peter
    • By habdou
      Hi,
      Does anyone know how to align a vertical drawer pull (Hardware) to the right or left rather than center?
      Please don't say make the drawer to a door.
      Thanks
    • By Walde77
      I'm in the market for a travel laptop that will run Chief X +.  Ideally it would be a ultrabook 2 in 1 to be able to have a tablet with me (without carrying another stand alone tablet).  Does anyone have any insight or experience with Microsoft's Surface Book 2 -15" with the 1060 video card?  My local custom built computer shop says all of the ultrabooks/light weight units are going to lack the power needed to run Chief effectively.  Any thoughts?
    • By kylejmarsh
      I'm interested in building a new Mac setup for running Chief.
      Currently I have a Mid-2014 Macbook Pro, 2.5 GHz Intel Core i7, 4 Cores, w/Nvidia GeForce GT 750M 2048MB GPU. This setup will run Chief Models well until they get to about 3000 SF - by 'well' I mean they are pretty lag-free in 3D mode (with optimized exterior camera i.e. cabinet, interior casing, plumbing layers 'off' to decrease total modeled polygons). I've noticed that on a recent 6000 sf project, I was often waiting for the model to 'rebuild' even getting a dialog at times - my productivity was way down, and I was frustrated (and bored at the same time - waiting for all that refresh time.) In Layout, I'm often waiting for views to refresh / render for me, especially 'plot line' views - even when I'm working with a smaller model, in order to make a set of CD's it seems that I wait just a bit too long for everything to happen - especially if this is my business. So it seems I've located a place where my current setup is lacking.
      I'm committed to running a Mac - although the concepts of a setup should be similar even if you're planning a PC.
      Mostly I'm using Chief to create models of homes and renovations of 1500 - 4500 sf, and to create Construction Docs from the model. I do a few renderings through the course of the process, but no video exports. Mostly I'm interested in a model that rebuilds quickly, and layout views that update quickly - and if I could eliminate that tiny lag that happens with pretty much every operation - then I'd really be happy.
      What do I need Chief to do?
      1. A model that rebuilds quickly
      2. Layout views that update quickly
      What Computer do I need to make this happen?
      I'm tempted to get a Mac Pro tower from a few years ago which has twin 3GB video cards, bumping me from 2GB to 6GB. This also would have 6 cores, each running at 3.5 GHz - vs. my current 4 core / 2.5 GHz setup. I can get one of these for $1800 - so as soon as it saves me 18 hours it's all gravy after that.
      In regards to the Model Rebuilding time, it seems like the video card upgrade won't do much to help my cause. From what I can gather, the model rebuilds itself using only one core, no GPU, and so is entirely dependent on the clock speed of your processor - so going from 2.5 to 3.5 would be almost a doubling, which is nice - but not the kind of gains I was hoping for (but I may just have to settle for).
      // I read something recently by a Chief Programmer which said the model had to be rebuilt in a certain order, and thats why they couldn't split it across the different cores. I wonder why they can't at least split each floor level on a core, and the terrain on another core - but I'm not a coder so I can't answer why not. There's probably a good reason.
      My question is - and I haven't been able to find any info about it - is what effect does the video card have on Layout Views updating?
      I did some basic testing using the Activity Monitor utility, watching CPU and GPU history as wall as CPU load graphs, and got the following results:
      Creating Plot Lines (Layout) seems to rely on the CPU, but seems to split the load across all the Processor Cores. So for this, I assume more cores is better, as well as processor speed. GPU seems to be idle during this process.
      Working in Elevation View (actually an orthographic camera of the 3D model). Zooming in and out, the load split across processor cores.
      Manipulating the model and waiting for the model to update, we also get multi-core activity, and little action on the GPU. The only time we get GPU action is when we look at things in the 3D exterior camera - standard rendering style.
      So I guess that leaves me with some answers. It basically seems like:
      1. The GPU isn't a big deal, and even my 2GB card is pretty good
      2. More Cores + more speed are my friend. Although the graphs don't have a number, watching the percentage on the processor shows that it was hitting 100% during the layout zoom operations - so I'm out of processor.
      So this changes what I buy somewhat. Guess I'm looking for Cores + Speed instead of upgrading to a massive video card. Does anyone else have insight to this?
    • By JonBDesigns
      Hi Everyone!
      I just finished building a custom AMD Threadripper 1950x system. I would like to benchmark my system. I am super interested how my system will stack up compared to a dual Xeon system. I thought that there was a thread started which contained a common file that everyone was using to compare Raytrace times--however I was unable to find it after a quick search of the discussion boards.
      Please let me know if I need to move it somewhere else, or if there is already another thread started.
      Peace,
      Jon
      Specs:
      AMD Ryzen Threadripper 1950x (OC to 3.9 with plans to go further)
      Gigabyte Aorus X399 motherboard
      Asus ROG STRIX GeoForce GTX 1080 OC
      Corsair Vengeance 32 gb 2666 quad channel RAM
      512 M.2 Samsung 960 Pro
      2x 256 M.2 Samsung 960 Evo
      2TB Seagate Barracuda HD
      Corsair HX750i Platinum Power supply
      Corsair H115i Water Cooler
      Corsair Graphite 780T case
