SNestor
Gable End with Step out - how?
I'm wondering how to make a stepped out gable end.  Is it possible to turn an attic wall into a pony wall...so that the upper wall is say 6-8" thicker than the lower wall...creating a step out that could be decorated with corbels?
If you can use a pony wall...then do you use P-Solids or material regions?
See pics of examples below...
Steve,
Why don't you try it and see if it works.
Steve,
Funny :)
I was wondering the same thing.
I guess it's easier to ask and get someone else to do it for you.
Although it would probably be quicker to try it yourself than make the post.
I tried the pony wall...and could not get it to work. Honestly - I thought someone probably had done it before and would just tell me. I know I could do it with PS but it wouldn't frame.
must be more complicated than I thought. Sometimes getting answers on the forum keeps me from wasting a lot of my time.
The pony wall method works.
What trouble are you having?
You may be seeking Chief to "frame" that detail, but there is no way I know to frame it correctly in Chief unless you manually place framing members.  A pony wall method would only give you a different wall thickness in that area, when in fact that framing is typically added once the wall is framed.
Personally, id use a material region.  I love that tool, and it breaks the siding layer of the main wall.
Guys...thanks for the slap down.  I worked a little harder...and success.  This forum is like a bad drug...kind of makes you just lazy.
I didn't have the pony wall "main layers" aligned properly.  Figured it out though...so I'm feeling good.
I used a pony wall...just took the same wall as below...added a new layer of Fir Stud at 16" oc.  This new layer was not part of the main layer.  I haven't tried to "frame" it...not sure how it would look.  I am going to experiment with using the wall material region.  I think it would be quicker and easier...and in the end really all I would need.
I've attached my Gable End plan if anyone is interested.
Gable Step Out Plan.plan
Johnny...I did get it to frame somewhat accurately.  It probably would still need some tweaking...but, at least the studs for the step out showed up.
    27490
    JonBCamerata
    JonBCamerata
  • Similar Content
    • By srjbb97
      How do I get the siding to show up on in the gable? See attached pictures.. Also, what is the best way to align the eyebrows along the front?
      Thanks in advanced..
      Chief Architect X9
    • By Designer100
      I cannot figure out how to ge small gable roof above Bedroom 4 on study side to fill out correctly, fascia not showing.. Also porte-co-chere on 1st floor roof to be flat with siding on left side on front part.
      Any help would be appreciated.
      Thanks
      McafeeRemodelingNewplan.zip
    • By blueriver
      I have a persistent problem with gaps in my porch ceilings in between the finished surface and the underside of the roof structure.  I know it has to be a setting i have wrong but i cannot figure it out! Current project is a barndominium with a gable porch.
      Thanks in advance
    • By SNestor
      I think I have an issue with my "template" plan as I cannot get walls located above invisible walls to build correctly.  The wall in the attached plan is where the ceiling transitions from 12' tall to a room with a 9' tall ceiling.  I attempted the same drawing in a stock Chief template plan and everything worked like it's supposed to...so, I gather I have a setting in my template plan that is goofy...
      Thanks!
      Plan attached:   Gable End Wall Not Building Plan.plan
    • By knnbmr
      Hello - I need to finish a plan but can't seem to figure out my very last little issue. I need to add a small gable over this front porch. The roof is a high shed roof, gabled on the right side. Any ideas? I've tried changing the porch roof to a gable and nothing happens, I've tried a bunch of other little things and all it does is mess with the roof pitch of that area.
      Thanks in Advance - Keenan
