rdHobbyist Posted May 7, 2016 Share Posted May 7, 2016 Hello, I'm a new hobbyist using Premier X7, so please forgive the absences of industry jargon. I'm trying to create a shed and when I complete the shed outside walls, the two, last placed walls, extend below the floor. Any ideas why? Link to comment Share on other sites More sharing options...
chief58 Posted May 7, 2016 Share Posted May 7, 2016 it help to post the plan so we can see how you have things setup Link to comment Share on other sites More sharing options...
ShaneK Posted May 7, 2016 Share Posted May 7, 2016 Post the plan please, but try this. Open wall dbx/go to structure tab/default wall height. Link to comment Share on other sites More sharing options...
dshall Posted May 7, 2016 Share Posted May 7, 2016 Some walls are backwards and they don't have finish on one side. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 7, 2016 Share Posted May 7, 2016 If you care to see walls that really extend below the floor take a look at this one. Tech Support has been working on this one for me forever now but if anyone else has seen this or cares to comment please do. Link to comment Share on other sites More sharing options...
dshall Posted May 7, 2016 Share Posted May 7, 2016 If you care to see walls that really extend below the floor take a look at this one. Tech Support has been working on this one for me forever now but if anyone else has seen this or cares to comment please do. Open wall and uncheck floor hangs on wall Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 8, 2016 Share Posted May 8, 2016 If you care to see walls that really extend below the floor take a look at this one. Tech Support has been working on this one for me forever now but if anyone else has seen this or cares to comment please do. Can you attach that plan? I'm really curious. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 8, 2016 Share Posted May 8, 2016 All good there Scott, Do you think maybe the bricks are too heavy? Link to comment Share on other sites More sharing options...
ShaneK Posted May 8, 2016 Share Posted May 8, 2016 Foundation wall uncheck "floor hangs on wall" Link to comment Share on other sites More sharing options...
Chopsaw Posted May 8, 2016 Share Posted May 8, 2016 Yes I have checked all the foundation walls now and none have "floor hangs on wall" checked. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 8, 2016 Share Posted May 8, 2016 This is how the wall above (as viewed from the outside) keeps framing. I know that I can manually straighten and reframe it but I would really like to know what is causing this. I think it must be somehow related to the foundation because the sill plate is sinking into the masonry at the same angle and I think there is no way to edit that. Strangely enough the subfloor does not follow this pattern. The adjoining wall on the left (of the Wall framing Detail) is also affected in a similar way but not the other two. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 10, 2016 Share Posted May 10, 2016 Chopper, I just sent you a PM. Link to comment Share on other sites More sharing options...
rdHobbyist Posted May 18, 2016 Author Share Posted May 18, 2016 I think I'm just out of my league here. I could probably build it faster in Maya...just don't know this software well enough. I've watched many, many tutorials, but perhaps there is a book that would be a better training tool? I have attached the file here. Shed.plan Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 18, 2016 Share Posted May 18, 2016 1. Change the Wall Type so that: a. The Foundation is built to Layer 3, not Layer 1 b. The Bead Board Thickness is at least 7/16" - currently you have it set at 0" 2. Build the Foundation. Here's a pic with Foundation and Roof Link to comment Share on other sites More sharing options...
rwaldrondesigns Posted February 27, 2024 Share Posted February 27, 2024 I'm having a similar problem, which makes it quite difficult to properly dimension interior elevations.My wall is drawn to be 82", but I can't get a proper dimension! Did we ever figure this out? Link to comment Share on other sites More sharing options...
Chopsaw Posted February 27, 2024 Share Posted February 27, 2024 1 hour ago, rwaldrondesigns said: I'm having a similar problem, which makes it quite difficult to properly dimension interior elevations.My wall is drawn to be 82", but I can't get a proper dimension! Did we ever figure this out? I am not sure your situation is unexpected. It appears that the "railing" ? wall is building from the sub floor level and your are dimensioning from the finished floor level. It may just be a matter of adding 3/4" to your railing wall height. Link to comment Share on other sites More sharing options...
