cjanderson66 Posted April 8, 2016 Share Posted April 8, 2016 In the picture I have attached it is showing that my studs and my plate in a couple of the rooms are below the top of the stem wall. All the settings appear to be the same for all the rooms. I have had this happen before but can't seem to figure it out. Please help. Thanks. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 8, 2016 Share Posted April 8, 2016 Would you care to post the #&*^# Plan? Link to comment Share on other sites More sharing options...
cjanderson66 Posted April 8, 2016 Author Share Posted April 8, 2016 Would you care to post the #&*^# Plan? Here you Go Joe. Also not sure why my plans are so large in size, maybe you can figure that one out too. Thanks lewis proposed plan.plan Link to comment Share on other sites More sharing options...
Mark3D Posted April 9, 2016 Share Posted April 9, 2016 You have pulled the bottom of the wall down i think to bring the stone down to the terrain best to check wall bottom default height and use slabs or other to extend your stone Link to comment Share on other sites More sharing options...
johnny Posted April 9, 2016 Share Posted April 9, 2016 You have pulled the bottom of the wall down i think to bring the stone down to the terrain best to check wall bottom default height and use slabs or other to extend your stone ^^^ that looks to be the issue. Wall materials regions would be an awesome solution if Chief would have allowed us to go around the corners with them. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 9, 2016 Share Posted April 9, 2016 I haven't confirmed, but assuming the guys are right about the wall being pulled down, I would probably recommend you consider using a pony wall for your foundation rather than pulling the wall down. 1 Link to comment Share on other sites More sharing options...
Northriver Posted April 9, 2016 Share Posted April 9, 2016 I deleted my first post after opening up your plan. I took an interior elevation of the walls in question and it shows stone on the interior of the wall continuing to the crawl space (Is that the design intent? ) as well as the exterior. Went to wall structure and you do have pony wall selected. Like the others said the wall was manually extended down. Nice design. 1 Link to comment Share on other sites More sharing options...
cjanderson66 Posted April 10, 2016 Author Share Posted April 10, 2016 Thank you all. That is exactly what the issue is. Everything time I have a exterior stone I bring it down to grade but did not realize that it brings the framing down. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 11, 2016 Share Posted April 11, 2016 If you are using a slab foundation, you can adjust this tool and drop the stone or brick Link to comment Share on other sites More sharing options...
