DMDesigns
Free Tile Textures 4 Chief X8
Hey Gang,
In celebration to the BEST upgrade I've seen in YEARS .. YEARS...    I created a set of textures in Chief that I thought I would share. A little something to give back to all these Sweet CA Users..!
FREE FOR LIFE, ENJOY -
Dave ;)
DMDz Chief X8 Textures.calibz
Dave, I'm getting Texture Missing on all but the Carrara Marble. What did I do wrong?
I'm not sure.. Has anyone else had this issue?
Well that is odd..! I guess X8 has another BUG. I wonder if I just attach a plan file with all the textures. Does this work?
textures.plan
Chief claims it works just fine. So I literally have no idea...
Well that is just weird... Mine came in just fine in X8... ?
Debra
Mine came in fine in X8 also.  Thanks Dave!!
:D   AWESOME..! Weird it does not work for some people.
D
Dave,
The textures imported perfect.
I imported the "DMDz Chief X8 Textures.calibz".  Then when I opened your plan file they all showed up for an easy reference.
Thank You!
David,
Thank you for your time and expertise!
I have no Idea why it doesn't work on my puter, is it a setting in windows 10 maybe?
I tried a new download of calibz file and the plan.  no joy. this is the error message I get.
Try the backup entire plan, select the files to be sent to a zip.
This is how a sample file download from Chief comes.
I think since you copied and renamed the original texture file, chief has lost its link to the location of the texture.
I had the same thing Michael had It seems its trying to read the texture from Daves drive which is D
Also one of the textures it displays one image and the preview window has another image.
Also if I click on the plan link on the blog page it opens directly into CA  instead of the window with an option where I want to save the file, which is very odd.
P.S
I think that carara marble texture was corrupt, Before when I downloaded the plan I couldn't see  textures displayed except  Carrara Marble was showing on one countertop, same thing as Cheryl noted, when I deleted Carrara Marble from my library, and uploaded the plan again I could see all the textures on the countertops except  Carrara Marble Texture. Strange but maybe there is something between Mac and windows.
P.S
I think that carara marble texture was corrupt, ......... Strange but maybe there is something between Mac and windows.
I just tested,  I am on a MAC,   the carara marble texture worked for me.
David,
Great Idea - BackUp ZIP of all TEXTURES..! File Attached -- Fingers Crossed..!!
Its very odd it works for Chief Architect and most users here, but why not everyone? It might be the fact that they are on my D: drive and when loaded up onto other peoples PC there C: drive can see them?
TexturesAgainFingersCrossed.zip
Hey Dave,
I just downloaded the Zip and unzipped into a folder... Did you take the Carrara Marble Texture out? Because it's not there anymore and everything it seems to work good now.
​As trying to read the D drive, yes I think that's what it does, because before I downloaded another plan and when I got the texture box come up I had where that person who uploaded file was storing his texture which was c:/ username/ and where that file was stored/name.jpg so go figure whats going on in there  :unsure:
    27648
    DarrinKoone
    DarrinKoone
  • Similar Content
    • By Renerabbitt
      POST 0
      You've found it! A thread offering up some of my favorite symbols and content for Chief Architect X-11.
      These items are for X-11 only. If you haven't updated yet I encourage you to do so, it's a great release.
      The following content is listed by category with both a link to the post within this thread for easy navigation and a link to a direct download if you won't to cut straight to the chase. new/recent uploads are in RED font
      CLICK ON THE "DL" FOR INSTANT .CALIBZ DOWNLOAD:
      CONSTRUCTION ASSEMBLIES/ARCHITECTURAL ITEMS:
      RABS 42 CABLE RAILING - DL    RABS MODERN FRONT DOOR AND DOOR ASSEMBLY - DL   RABS INTEGRATED SINK - DL NEW!!! 03/26/2020
      ENTOURAGE:
      RABS CHARLES-HILL GROUPED LIVING ROOM - DL RABS CHELTON GROUPED LIVING ROOM - DL    ACCESSORY HOME #1 - DL ACCESSORY HOME #2 - DL ACCESSORY HOME #3 - DL
      KITCHEN RELATED:
      3-ISLANDS - DL LA CORNUE 1908 RANGE - DL CAFE APPLIANCES, PAINTABLE(CORRECTED) - DL
      LIGHTING:
      PENDANTS AND SCONCES - DL-1 - DL-2 - DL-3 - DL-4 RECESSED NC HALO 4 INCH LED WITH HOUSING - DL NEW!! 03-22-20
      MATERIALS:
      TILE AND COUNTERTOPS #1 - DL 1(ONEDRIVE LINK) - DL-2 CUSTOM WHITES WITH PAINT TOOLBAR ICONS - DL-1 - DL-2 - DL-3 - DL-4 - DL-5 - DL-6 RABS RUGS 1V1 - DL          RABS STARTER KITCHEN MATERIALS PACK - DL         RABS FLOORING PACK 1 - DL            RABS OLD GOLDEN OAK FLOOR - DL
      SYMBOLS:
      FIREPLACE ASSEMBLY 1 - DL     ACKLES BED AND EDISON TABLE LAMP - DL-1 - DL - 2 TEAPOT MATERIAL EDITOR REPLACEMENT - DL-1 - DL-2 FINMARK TABLE FROM CB2 - DL FIREPLACE MANTLES 1 AND 2 - DL    RABS STRETCHABLE PICTURE FRAMES - DL
      VIDEOS:
      YouTube Channel
      Many of these I have personally made or modified. Some of the content may have been created by others for which I will give credit. Many of the materials have free licensing, so no credit is needed.
      Some of this content may slow down your program as I have a high powered machine and often times use complex and high resolution textures. I will try and give as much detail as possible. Use at your own peril!
      No but seriously dig through and enjoy, I've spent a good number of hours ensuring the quality of these symbols and will update them periodically- so CHECK BACK IN! and PLEASE GIVE A LIKE FOR THE POST OF ANY SYMBOL YOU LIKE, IT ENCOURAGES ME TO GO BACK AND REFINE/REDUCE/OPTIMIZE THAT SYMBOL. GIVE A DOWNVOTE AND IT'LL PROBABLY ENCOURAGE ME TO DO THE SAME THING...YOU'LL JUST BE A JERK FOR IT
      CHANGELOG:(PACIFIC TZ)
      Page 1:
        Post 0:
      02-12-2019- 4:45PM: Removed the poll, migrated this thread. re-uploaded from X11 public beta 02-20-2019-2:59PM: Added a Poll for user content requests 03-30-2020-6:49PM: Deleted Video Links and added link to YouTube Channel   Post 5:
      02-12-2019- 4:45PM: centered the hearth on the symbol   Post 18:
      02-12-2019-9:52PM: Posted and fixed DL links
      Here is a symbol to get you started:
      @Cheryl_C_Crane Think you requested this,
      RUSTIC BRICK 2.calibz
      Number of Textures: 2
      Map size: 1024x1024
      Filesize: 3.13 MB
    • By JGSpruell
      Chief Architect + Lumion + Photoshop
    • By ChiefArchitect
      Warm, sturdy, fire resistant materials common to a Tuscan home made this style an obvious choice for the Paradise Rises project. Stucco on the main house is accentuated with natural stone on the wrap-around porch and fireplace. Tile roofing is a bow on top.
    • By gelbuilding
      Like to share some material I`ve recently made.
      I have a sample renders i have done, not with CA.
      Maps included in zip file,basecolour, displacement, metallic, normal and roughness.
      Sample shots material ball and scene.
      Also calibz file so straight into CA.
      Resolution 512k
      Mini_Micro.calibz
      Mini_Micro_H&W_512x512_textures.7z
    • By carowe
      Is there a way to download a picture of a tile from a manufacturer's website and create a material?  I am trying to use the attached pics of tiles for a backsplash in a kitchen and have followed the instructions on the videos, but cannot get the tile to align properly.  I have attached pictures of the two tiles I'd like to show the client, and a picture of what happens when I try to use the material.
      Thanks!
