I have never used the plus or minus designation for dimensions but want to but I am checking it and nothing is happening.  I have a dimension, clicked on it, opened the dbx, unchecked default and selected + or - but no change.
What am I doing wrong?  I will PTP if necessary.
I concur,  I can't believe this has not come  up before.  I cannot get the plus minus sign either.
Maybe because the dimension is correct and isn't rounding?
Yep,  that is the reason.
IOW, it depends on what you have set as the smallest fraction.  if you have dims set to display a 1/16" fraction then the +/- will only be displayed if the actual dimension is not exactly a multiple of 1/16"
We can get it as a macro other then that I put my own +/- in the under additional text, trailing text in the dimension spec box
Apparently you are just drawing too accurately Dennis :)
even when I'm right I'm wrong!  ;o(
Thanks guys.
    27469
    THDesign
    THDesign
