mctabish Posted July 25, 2015 Share Posted July 25, 2015 I have been working on several other parts of my plan and not paying attetion to the main house. Somehow, my house has sunken into the ground. the property is on a hill and now my floor (which was and is still at 0) is now about 100 inches below the grade (file2.jpg)where the main house is located. I have tried selecting the rooms and raising them up (not the properway I am sure) but my "exterior room", which seems to be really screwed up, basically covers the whole floor plan and I cannot select the individual rooms (file1.jpg) How can I correct this? Thanks Bruce Link to comment Share on other sites More sharing options...
Kbird1 Posted July 25, 2015 Share Posted July 25, 2015 from you description of the exterior Room , it sounds like you may have a broken wall connection somewhere , check each level..... for weird stuff like this , it is always better to post the plan so others can look at it for you... M. Link to comment Share on other sites More sharing options...
mctabish Posted July 26, 2015 Author Share Posted July 26, 2015 Not sure how I look for this, but here is the plan. I did see something about "island walls" and found that and toggled, but I did not see a difference. I have not retoggled it off Thanks Bruce Link to comment Share on other sites More sharing options...
glennw Posted July 26, 2015 Share Posted July 26, 2015 Bruce, Did you change the Pad Elevation in the terrain dbx? Link to comment Share on other sites More sharing options...
BigKahuna Posted July 26, 2015 Share Posted July 26, 2015 Same think happened to me yesterday. I somehow accidently reset the pad elevation. Link to comment Share on other sites More sharing options...
lbuttery Posted July 26, 2015 Share Posted July 26, 2015 Chief should ask before acting on changes like this Lew 1 Link to comment Share on other sites More sharing options...
tommy1 Posted July 26, 2015 Share Posted July 26, 2015 I think Glenn has the answer. If your (1st. floor) floor height is still set to 0", then about the only other thing that could change this by looking at you image (and everything was okay before) is a change in the building pad. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 26, 2015 Share Posted July 26, 2015 looks like you forgot to "attach" the plan Bruce once you hit Ok after locating it. M. Link to comment Share on other sites More sharing options...
mctabish Posted July 27, 2015 Author Share Posted July 27, 2015 How do I change the pad elevation in the terrain dbx? I tried to attach and it was 75% when I hit add reply. I figured it would finish uploading. I will wait till 100% this time:)... Ok, there is the problem. My file is 35mb and it only allows 25mb. How to work around? Link to comment Share on other sites More sharing options...
Kbird1 Posted July 27, 2015 Share Posted July 27, 2015 Uncheck Auto height in the Terrain Specs. DBX , then you can set the height yourself. do a SAVE AS of the .plan file and then delete things like fixtures and furniture ,cabinets, etc ---- eg interior stuff nobody needs to see for this issue. 3D plants and Trees also ad mb to the plan and aren't needed for terrain issues. M. Link to comment Share on other sites More sharing options...
jcaffee Posted July 28, 2015 Share Posted July 28, 2015 On 7/27/2015 at 10:21 PM, mctabish said: Ok, there is the problem. My file is 35mb and it only allows 25mb. How to work around? Host the file on DropBox, OneDrive, etc., and provide a public link. joon Link to comment Share on other sites More sharing options...
4hotshoez Posted July 28, 2015 Share Posted July 28, 2015 Zipping the file shrinks it quite a bit, but DropBox it less work. Link to comment Share on other sites More sharing options...
