Kbird1 Posted June 4, 2015 Share Posted June 4, 2015 I have been able to do it no problem, for all the Dimensions , but the setting for doing it to Window and Door Labels has eluded me, even if I specify the Label with Height x width macros . Maybe it is just me it annoys? (in metric plans) but I don't want to edit each and every label cos it looks like a typo. Thanks M. Link to comment Share on other sites More sharing options...
Gawdzira Posted June 5, 2015 Share Posted June 5, 2015 Convert to the Imperial system. Link to comment Share on other sites More sharing options...
dshall Posted June 5, 2015 Share Posted June 5, 2015 Convert to the Imperial system. I think the world shuld forgot about that silly metric sistum and goin on back to the imperal sistem. Further pruf that us Americuns is dang smart. Link to comment Share on other sites More sharing options...
GerryT Posted June 5, 2015 Share Posted June 5, 2015 I'm not sure exactly what format you want but I assume (?) you just want to use a space separator. Attached is a macro that you can use in a lable. Format_Label.zip Link to comment Share on other sites More sharing options...
Kbird1 Posted June 5, 2015 Author Share Posted June 5, 2015 Thanks for the Replies , I assume this is a bug , I have never been able to get rid of it on Labels but was hoping a smarter Chiefer than me might have a solution. For Dims when working in Metric I usually turn off the separator all together , ie no space ,no comma but Labels always add the space regardless it seems , been this way for years and is a small pet peeve. Maybe they can be forced to show meters instead ? (marco only ?) ie 1.8m X 2.0m instead of 1 800 x 2 000 thanks for the macro too Gerry Link to comment Share on other sites More sharing options...
Ginkgohouse Posted June 5, 2015 Share Posted June 5, 2015 When I opened the Template "ProfileM.plan" supplied with CAX7, The label shows with no separation space when you use the Height Macro. However with the auto label, the space shows up ! Dont know where the format is driven from. Link to comment Share on other sites More sharing options...
GerryT Posted June 5, 2015 Share Posted June 5, 2015 Formatting for labels is internal to chief (outside of ruby macros) and not changeable. Auto label uses a space separator as this is most common. width and height do not use separators in order to allow the user to format as desired. Link to comment Share on other sites More sharing options...
Dan_Park Posted June 5, 2015 Share Posted June 5, 2015 Can you put the macro in the window defaults? If you check specify label in the defaults and add: %width%x%height%DH Or some other macro... Link to comment Share on other sites More sharing options...
glennw Posted June 6, 2015 Share Posted June 6, 2015 Dan, Yes, that works. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 6, 2015 Author Share Posted June 6, 2015 Can you put the macro in the window defaults? If you check specify label in the defaults and add: %width%x%height%DH Or some other macro... Thanks Dan and others I Finally figured it out ... I had already put the macro into my Default Label for Windows but none of the Labels changed. I was expecting it to change on ALL the windows as it was a Default , but I guess Labels are not Dynamic in this regard ?, so as all the Windows were already placed in the plan nothing changed, but I have updated each label manually now , and I have now also updated my Metric Template , so I should be good from now on... Thanks again all. Mick. Link to comment Share on other sites More sharing options...
