Dennis_Gavin
Any Way To Do A Bay Window With Jamb And Casing?
Are you talking about a mulled bay window that hangs on the wall or a bay with windows in it (as Chief defines them)?
Chief's bay window selected from the window icon.  Raised floor and lowered the ceiling
but I don't like not having a jamb with casing.
What else would you have other than a jamb with casing?   What you have shown is a site built bay window - which would involve installing 3 windows in framed openings.
As Alaska mentioned, there are such things as pre-built bay and box windows that are, in themselves, a "window" of sorts.  Is that what you want?
Such as this from Pella:
http://www.pella.com/windows/explore-window-styles/bay-bow.aspx
Dennis,
Let me know what you need.  If it's Pella, I have a whole bunch that I've predefined as "Custom Window Symbols" so I should be able to make it work for you.
Thanks Joe but I have done it with fillers and molding polyline.  Just wanted to see if
there was something I was overlooking.
Hi Dennis , another  way I used last time I did one of these was to Use the Pass Through , sized etc to fit "into the Bay"  , you have to place the PT to the side at 1st , then drag it into the Bay Opening though.
Mick - Good idea.  Will keep that in mind........or at least TRY to!  ;o)
General venting, trying to use this yesterday
I don't think the bay, and bow units work very well at all.
The exterior casings will not connect even with the no framing between command checked.
I cannot resize the side windows to be big enough to connect to the center picture unit. Even with ignore casing for opening resize checked off.
Hey Joe, how do/did you make custom units.
Hi. I agree with MPDesign and have had the same issues;-Chief's Bay windows don't work well if you want a pre-fab, mulled bay window. Joe Carrick, would you mind posting your bay window symbols in the symbols forum or a link here? thanks.
Here's an example. There are almost 30 symbols in the set of Andersen Bay Windows.
I created them using Chief Solids for the various pieces and sized them to fit.
This particular Symbol was done as an Exterior Fixture and is used in concert with a "Pass-Thru". It could be converted to a "Custom Window" but since CA has not yet fixed the way the Custom Windows work, I have held off on doing that. It means the Window Schedule has to be "hacked" but otherwise it's easier than fighting with the Window Tool.
Hopefully CA will fix the problems with the Custom Windows - introduced in X6 but never adequately finished.
45-P4035-20 Anersen Bay Window.calibz
You can get the flankers to join if you use hold down the ctrl key and resize. If you use a small exterior casing it will close the siding gap.
BUT they are a pain.
Wow Joe that is very generous of you! Thank you, will put to use since Anderson is right in the neighborhood! :)
Dennis- I played around with the ctrl override, success! thank you for the reminder.
cheers!
There is only one of the Andersen Windows in that attachment, not the entire set.
With Chief's window , if you tab to select the individual window and then pull on the side handle , (sometimes takes a few tries) you can usually get the windows to join on the corners , once you have done all 3 windows it doesn't look too bad for most views though it could be nicer.
    27882
    Boots9
    Boots9
