JonathanK Posted August 26 Share Posted August 26 So I'm looking into a macro for my railings that if it's a railing, the macro will populate "Railing", and if it's a halfwall the label will populate "Halfwall". I think I got it so that it will work right, and I created a new "Wall, Labels, Railing" layer so that just my interior railings can have a label and not have Wall, Labels on for everything. My problem is...as soon as I turn on this layer the entire plan slows WAAAAAAY down. We're talking smooth as butter to herky-jerky. I think I have the macro optimized but not 100%. Either way, it's 1-2 railings in an entire plan. Seems like a real bummer to not be able to utilize this kind of automation. I've posted the plan, so if someone wants to poke around, feel free. Railing Macro.plan Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 26 Share Posted August 26 Did not slow down on my system Link to comment Share on other sites More sharing options...
DBCooper Posted August 26 Share Posted August 26 (edited) I didn't notice any slow downs either. Must be something else going on. Maybe try a reboot? On a side note, I looked at your macro and didn't see anything that looked weird but I am definitely not a macro expert. One thing I thought though was that you could be using "owner.is_railing" to make sure you actually had a railing. Not sure but I thought that if you turned a railing into a wall that some of these other macros might still give you something back that makes you think it is a railing when it really isn't. Too bad there isn't a macro that would just tell you that it's a halfwall because that would make it even easier. Personally, I would just setup my railing and halfwall defaults to make the label what I want and not bother with the macro but that is only because I don't mess with macros that much. Edited August 26 by DBCooper Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 26 Share Posted August 26 (edited) Good idea to state when the slow down occurs. For me, selecting the railing makes the slow down happen..which is b/c of the 4095 box newel, not your macro. Also have you considered displaying your railings like this? Edited August 26 by Renerabbitt Link to comment Share on other sites More sharing options...
JonathanK Posted August 26 Author Share Posted August 26 If I turn the label layer off, the slow down goes away. When I turn the layer on, the slow down occurs. And the slow down is mostly if I go to draw new walls, or other items. I can zoom and pan around the plan fine, but trying to draw anything slows down.@Renerabbitt, we did talk about that, but they want to try the label first. What's wrong with the 4095 box newel? Link to comment Share on other sites More sharing options...
JonathanK Posted August 26 Author Share Posted August 26 Here's a video of it... You can see when the layer is off, it's smooth. When it's on, it's jerky. Again, not much...but it's actually enough of a lag that you misclick things a lot. Railing Macro Video.mp4 Link to comment Share on other sites More sharing options...
JonathanK Posted August 26 Author Share Posted August 26 54 minutes ago, DBCooper said: I would just setup my railing and halfwall defaults to make the label what I want and not bother with the macro but that is only because I don't mess with macros that much. I'm not going to lie...I actually didn't know that there was a "Halfwall" tool I'm still curious about this macro...but this might be what we do. Because if I just use plain text and not the macro then there is no slow down. Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 26 Share Posted August 26 19 minutes ago, JonathanK said: What's wrong with the 4095 box newel? try it for yourself. change to a box newel and draw out your railing wall Link to comment Share on other sites More sharing options...
JonathanK Posted August 26 Author Share Posted August 26 Weird...it's not an overly complicated shape. You think something is wrong with the symbol, and that's causing the slow down? Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 26 Share Posted August 26 8 minutes ago, JonathanK said: Weird...it's not an overly complicated shape. You think something is wrong with the symbol, and that's causing the slow down? I would report it, and in the meantime just make your half wall versus railing wall macro layer dependent in other words make your out of the box half wall go onto a unique half wall layer and so if the layer includes half then it's 1/2 wall if it includes railing it's a railing otherwise let it report automatic description Link to comment Share on other sites More sharing options...
JonathanK Posted August 26 Author Share Posted August 26 That's another way to do it. Thanks, Rene. Link to comment Share on other sites More sharing options...
Chrisb222 Posted August 27 Share Posted August 27 19 hours ago, JonathanK said: My problem is...as soon as I turn on this layer the entire plan slows WAAAAAAY down. Turning the railing label layer on and off made no difference for me, super buttery smooth either way. Link to comment Share on other sites More sharing options...
JonathanK Posted August 27 Author Share Posted August 27 Thanks, Chris. Weird...wonder what is going on then on my end. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted yesterday at 04:23 PM Share Posted yesterday at 04:23 PM There's definitely something weird going on and it absolutely has something to do with your macro. Its not anything wrong with the macro itself though. Chief is just having a difficult time executing certain name:value pairs for some reason. I didn't dig very deep, but its easy to prove. Try pasting the following name:value pairs directly into the label for that railing: panel_rail_length num_whole_newels num_balusters length layer You'll probably find that the last 2 work just fine but that the program actually crashes with the other 3. Link to comment Share on other sites More sharing options...
